Qi charging mat flashing both indicator lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TJenkins, Feb 25, 2018.
  1. Feb 25, 2018 at 11:30 AM
    TJenkins
    TJenkins [OP] New Member
    2017 black Tacoma TRD Sport
    leveling kit, fuel 17" wheels, TRD PRO grille
    New to Tacoma world, so hello to all. My charging mat worked for the first week I had it. Now, the mat doesn’t charge and the two indicator lights keep flashing. Anyone know how to fix this or what’s causing the issue? Or is this something I need to have the delearship look at?
  2. Feb 26, 2018 at 5:52 AM
    BlazingTaco18
    BlazingTaco18 Member
    Dave
    CT.
    2018 Blazing Blue Tacoma TRD Sport DCSB
    I had the same problem. I have a iPhone X and the thick Otter Box case was causing the two lights to flash and not charge the phone. They said it was causing the charging mat to overheat. Found a thinner cover and all is well now. If you don't have a case it could be the position your placing your phone in. I find that placing the phone on the mat and pulling it towards the rear of the truck so the phone hits that little lip works best.
  3. Feb 26, 2018 at 6:26 AM
    TJenkins
    Thanks, it started working again later that day. I have a thin spigen case on my iPhone X. Hell, who knows
  4. Feb 26, 2018 at 7:10 AM
    BlazingTaco18
    Dave
    CT.
    Yeah, mine would work fine and then I'd look down after driving for 10-15 minutes and the lights would be flashing. Glad to hear it's working now.
    TJenkins[OP] likes this.
  5. Feb 26, 2018 at 7:15 AM
    Sammie
    Sammie :D :P ;)
    NC
    ‘17 Tacoma BBP
    That’s odd because I have a X with otter box and it charges fine.
  6. Feb 27, 2018 at 7:00 PM
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
    I have the iphone x and I get both lights flashing whether I have the case on or not. Troubleshooting says that if the pad overheats it will do that, but that can't be the problem here because it does it in below freezing weather when the truck is completely cold. If anyone has found a solution, I would appreciate hearing about it.
    Tacoma816 likes this.
  7. Nov 14, 2019 at 6:00 PM
    Ronin47
    Ronin47 Paulatim
    Los Angeles
    19 Cement TRD OR 4x4
    Same exact thing happening with me except with an android. Tried with and without case, both lights keep flashing and the car's parked in cold weather, can't be an iverheating issue. Ty
  8. Jul 17, 2024 at 4:48 PM
    LTLaker24
    LTLaker24 Member
    Larry
    2021 TRD Sport 4x4 Double Cab
    This doesn't happen to me. I have a Google Pixel. But it happens to my son when he uses his iPhone.
    Damn u Steve!
