Qi Delete
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C-Rok275, Jan 1, 2024.
  1. Feb 26, 2024 at 8:18 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    reviving this in the hope for a little help with part number look up. I have had my 22 MT shifter boot/bezel+ the plastic trim piece off a few times now I have broken the clips. Does anyone know how to look up this part (assuming it comes with the MT boot). If I can get a good deal with one of the parts sales, I wouldn't mind having an extra one so I can fix the broken clips and if it comes with the boot I can have it re-trimmed with a material I would like better. I know it is a longshot but I thought I would ask.
  2. Feb 26, 2024 at 8:25 PM
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    @Jeff Lange might know that
  3. Feb 27, 2024 at 9:28 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    There is a little more room. About twice as much as what you have now
  4. Feb 27, 2024 at 10:44 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Full assembly with the boots (shift and parking brake):
    58804-04050-C1 - Black/Silver (Trim 14,22,23)
    58804-04050-C2 - Black/Gray (Trim 15,24)
    58804-04050-C4 - Matte Black (SR Trim 14)
    Shift boot only:
    58808-04040-C0
    Bezel around shift boot only:
    58831-04020-B1 - Black/Silver (Trim 14,22,23)
    58831-04020-B2 - Black/Gray (Trim 15,24)
    58831-04020-C2 - Matte Black (SR Trim 14)
    Jeff
  5. Feb 27, 2024 at 11:09 AM
    bcmbcmbcm
    Brett
    Thank you! So to confirm "58804-04050-C4 - Matte Black (SR Trim 14)" is a full SR manual transmission assembly with black (likely plastic) trim? If so this would be good as I have changed out the rest of my trim already..
    Also, is there any way you can pull up a non-QI bezel assembly for a 16 MT? That way I could swap the whole deal all at once.
  6. Feb 27, 2024 at 11:13 AM
    Jeff Lange
    Calgary, Canada
    Yeah, that's correct.
    58810-04020-C0 is the non-Qi assembly.
    Jeff
  7. Feb 27, 2024 at 11:24 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The manual version wasn’t very available from what I remember when I bought my non charger tray. I went with the 4 cylinder auto version. Took the tray out of it and installed it into my existing floor console front half. Only buy the manual version if you really need a new front half.
  8. Feb 27, 2024 at 11:38 AM
    bcmbcmbcm
    Brett
    Thanks guys!
    Yes my clips are screwed up a little and I drilled an extra hole so I wouldn't mind starting over with all new parts.
    So for my 2022 MT I will be using:
    58810-04020-C0 2016 Non QI manual transmission assembly
    58804-04050-C4 2016 SR Manual transmission boot/bezel/plastic panel.
    This will essentially replace all plastic parts from under the dash to the armrest/cubby with nonQI and black trim around the shift boot.
    Thanks again!
