QI Pad Lifting/Bubbling Up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by El_Jefe, Sep 17, 2019.
  1. Jan 7, 2023 at 7:30 PM
    #101
    TRDPRO-M
    TRDPRO-M Well-Known Member
    TRD Pro 4X4 cement
    Seat mod, led mod, decal mods
    If you need the part number let me know
  2. Jan 15, 2023 at 5:41 PM
    #102
    Gummieman
    Gummieman Member
    2016 TRD Off Road
    Raptor Lights Roof Rack Winch
    I'd spend the money for a new rubber, but I read somewhere (so many posts that I don't remember where) that the bubble occurs again on a new piece of rubber.
    How is your new piece holding up?
  3. Jan 15, 2023 at 7:29 PM
    #103
    mabupa
    mabupa Well-Known Member
    Miguel
    2021 trd off-road 6 speed manual
    My 2021 did it at 12k miles. I only tried the thing once and never used it again after seeing how slow it was and hot that area got. I used one of the spare blanks and installed a dual USB fast charger and problem solved. I’ll deal with the bubble one day, but for now, I just keep a big pack of gum and sun glasses there.
  4. Jan 15, 2023 at 7:44 PM
    #104
    TRDPRO-M
    TRD Pro 4X4 cement
    I replaced it over 6 months ago and no issues. I got it from Toyota. OEM. It’s a two part piece, and the rubber can be replaced separately Very easy
    Gummieman and mabupa like this.
  5. Jan 15, 2023 at 9:55 PM
    #105
    USATRDR8CR
    USATRDR8CR Well-Known Member
    Orange County, CA
    2018 MBM TRD OR DCLB
    Qi charging pad rubber part # 861C4-04010
    I used some 3M double sided tape between the pad and the charging/heating element for added measure.
    Hopefully, it doesn’t bubble up again. I can see why it would bubble, the rubber pad needs some ventilation holes to vent all the heat that the charger generates.
    stftaco likes this.
  6. Jan 16, 2023 at 5:08 PM
    #106
    TRDPRO-M
    TRD Pro 4X4 cement
    I agree. Needs better heat dispersement.
  7. Jan 16, 2023 at 5:08 PM
    #107
    TRDPRO-M
    TRD Pro 4X4 cement
    I never even used it when it bubbled. And I am the original owner.
  8. Jan 16, 2023 at 5:21 PM
    #108
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Agreed…my 19 did it twice, both times replaced under warranty, then did again now out of warranty. Ive just dealt with it, it’s a flawed designed part. As others have said, the charger is useless anyway.
  9. Jan 16, 2023 at 5:47 PM
    #109
    TRDPRO-M
    TRD Pro 4X4 cement
    Maybe I’ll pull the power on it if it bubbles up. And just throw mints there. No power should equal no heat
  10. Jan 17, 2023 at 7:23 AM
    #110
    USATRDR8CR
    Orange County, CA
    It happens even if you don’t use it. The heat from the transmission tunnel and the fact that there is nowhere for it to dissipate is the cause of the of the bubbling.
    The next time you drive the truck for a while, touch the rubber pad and you will see how warm it gets.
  11. Jan 18, 2023 at 11:49 AM
    #111
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    This happened on my 2018 as well and I've never used it. I've read somewhere that you can replace the entire cubby with a non-Qi model which gives a deeper pocket.
    Is there a video somewhere about how to physically access it to replace, glue, etc?
  12. Jan 18, 2023 at 11:54 AM
    #112
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
  13. Jan 18, 2023 at 5:35 PM
    #113
    TRDPRO-M
    TRD Pro 4X4 cement
    I also thought of swapping it out for the pocket. But hurts resale
  14. Jan 22, 2023 at 7:39 AM
    #114
    Gummieman
    Gummieman Member
    2016 TRD Off Road
    Does it still charge your phone with no issues now that you cut off the rubber?
  15. Jan 22, 2023 at 8:12 AM
    #115
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'll have to try
  16. Jan 23, 2023 at 4:15 AM
    #116
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Can't say I've ever been able to replicate this. Without using it I don't notice any heat beyond the temperature of the other surfaces of my interior.
    Furthermore, maybe I've just gotten lucky but I've not had any bubbling issues with my 2017, which was actually built in 2016.
  17. Jan 23, 2023 at 5:11 AM
    #117
    TRDPRO-M
    TRD Pro 4X4 cement
    Just be careful what you try, you can get the rubber with the trim oem from Toyota for like 40 bucks
    But the electronic part is 700. Just a reminder. As I posted before I did the oem rubber replacement.
    Still going good
    shotgunbilly420 likes this.
  18. Apr 16, 2023 at 1:37 PM
    #118
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    Yeah min is bubbling now and I’ve never used it.
  19. Apr 16, 2023 at 6:40 PM
    #119
    TRDPRO-M
    TRD Pro 4X4 cement
    Get it from Toyota. 40 bucks easy fix. Easy replacement too
  20. Jun 20, 2023 at 10:04 AM
    #120
    afgixxer
    Tennessee
    Has anyone used the TSB to fix it?
