Qi problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jzale5313, Jun 17, 2018.
  1. Jun 18, 2018 at 3:00 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    My phone gets hot no matter what Qi charger I'm using. One of the drawbacks of the technology.
  2. Jun 18, 2018 at 3:02 PM
    brownmound
    brownmound Well-Known Member
    If I had my way I would replace it with a breakfast taco warmer.
    H3ATH3N2016, chasingtails and Mnmlod like this.
  3. Jun 18, 2018 at 3:07 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    :drool:
  4. Jun 19, 2018 at 1:00 AM
    Randomg1234
    Randomg1234 Active Member
    2018 Toyota Tacoma TRD Off-Road 4x4
    So, I have been using the official OEM wireless fast charger at work for some time and it works great, doesn't heat the phone up much (has a fan built-in) and works relatively fast. However, in the Taco, it heats up too fast. I have not done thorough testing yet, but I believe because the Taco charger does not have a fan, when using the fast charging mode on a Samsung phone it overheats if it believes it is a fast charging model. So, I turned off fast wireless charging in the settings and it appears to not have the flashing lights issue in the Taco. Just a thought. Personally, I like the idea of a wireless charger, but in a truck, it is difficult because bumps and sharp turns could move the phone from the charging position. Good idea, poor execution IMO.
  5. Jun 19, 2018 at 3:11 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    It's fine, it's been heating up my S4 for 2 years without a problem.
  6. Jun 20, 2018 at 3:16 AM
    CountofQ
    CountofQ Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    Turned off fast charging? Is that a phone setting you are referring to, or a setting in the Tacoma?
  7. Jun 20, 2018 at 4:33 AM
    TacoWil
    TacoWil Well-Known Member
    2018 Blue Tacoma TRD Pro
    I use fast wireless charger on desk, doesn't get hot. Galaxy S8.
    In Taco sometimes gets hot especially in hot weather. Also Galaxy S8 has issues with wireless charging, sometimes need to restart the phone and problems are solved.
  8. Jun 20, 2018 at 5:37 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    My Note 8 charges fast and to 100%. It works better then the phone is placed in one direction vs the other, but both work.
    The only time the phone has gotten warm/hot was when I had a magnetic phone mounting ring attached to the back.
  9. Jun 20, 2018 at 9:11 AM
    Randomg1234
    @CountofQ I apologize for any confusion. It is a setting that can be changed within the software of the Samsung phone. I am not sure if it is only on the newer models, but after using an OEM fast wireless charger, I noticed that I had the option within "Advanced Features" under "Accessories" to turn off "Fast Wireless Charging".
    I still need to test more, but like others have said, I have not had an issue with the phone getting hot like it does in the Taco on the OEM wireless charger.
    CountofQ[QUOTED] likes this.
  10. Jul 5, 2018 at 7:54 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Today my phone was making a strange beeping noise. Noticed the QI pad had two different lights on it, normally just has the one when it's charging. My phone appeared to have a notification but it was gone by the time I looked at it. Phone was really hot... It had only been in the charger 10-12 minutes. Anyone know what was going on?
  11. Jul 6, 2018 at 6:19 AM
    Randomg1234
    Yeah, I have had the same problem. I am not quite sure what is happening. My theory is that the phone is getting too hot and the charger is detecting that. I have never had this problem with a Samsung brand wireless charger on my S8+.
  12. Jul 6, 2018 at 6:29 PM
    CountofQ
    Duluth, MN
    I have that problem about daily on my S8+.
  13. Jul 6, 2018 at 6:46 PM
    My Name is Rahl
    Man, all ya'll having problems with your Qi charger. Makes me think I have the only Qi charger that works right. I have an S8 and have charged my phone to 100% multiple times.
    BSFord likes this.
  14. Jul 6, 2018 at 8:59 PM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    Front camera? Does it show up on the screen in the cab?
  15. Jul 6, 2018 at 9:07 PM
    #35
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    when that happens for me, most times I can fix it by turning the Qi charger off and then on again after ensuring my phone is centered and pulled to the front. Some times if it is too hot, that will not work.
  16. Jul 6, 2018 at 9:16 PM
    #36
    dreadedsoldier
    dreadedsoldier Well-Known Member
    Utah
    2016 Quicksand TRDOR
    I have the same thing happen on longer drives and when it does it my phone seems rather hot. Maybe it’s a safety feature?
  17. Jul 6, 2018 at 10:02 PM
    #37
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup
  18. Jul 7, 2018 at 5:18 AM
    #38
    Randomg1234
    Has anyone seen anything in the manual about it?
  19. Jul 19, 2018 at 4:56 AM
    #39
    IanNimtz
    IanNimtz New Member
    Ian
    2018 Silver Sky Metallic TRD Off Road DC SB Premium Package
    Stock
    My X charges pretty slow with apple leather case. Is there something you do different? I have to put it in the bottom left corner of the Qi pad to get it to charge.
  20. Aug 8, 2018 at 5:00 PM
    #40
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Note 8 always worked great. Other day heard a crazy sounding chime and figured out it was qi charger flashing. Phone very hot. Qi pad bubbled up in center. Happened 2 more times. Anyone else have issue? Wondering what fix will cost or if I can bootleg something in that spot since warranty out
