QI Wireless Charger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Taco4x4, Jan 19, 2018.
  1. Jan 19, 2018 at 1:28 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I am in the process of planning my install.
    I will not use the OEM Charger because of cost and separate Certification ECU. I am searching for an aftermarket 3-Coil PCB with 12v input. There are many with 5v input, but I don't want to use a step-down converter. I am also considering the GM 13521066 because it has it's Certification ECU built in and it accepts 12v.
    Charger
    861C0-04010
    Charger Connector
    90980-12368​
    Charger Connector Repair Terminal
    82998-24290 JPN
    Switch
    861C6-06011
    Switch Connector
    90980-12614​
    Switch Connector Repair Terminal
    82998-12870 JPN
    GM alternative
    Charger
    Harness
    23124536
    Connector
    Terminal
  2. Jan 19, 2018 at 1:39 AM
    05Taco4x4
    2TR-FE Enthusiast
