QI wireless charger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeeptec, Oct 13, 2018.
  1. Oct 13, 2018 at 5:36 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    My Samsung S7 is sensitive to the placement, and, it must have the case off.
    When I picked up the truck, the dealer actually said to me, that my phone was the first one he ever saw actually start to charge when placed on the pad.
    I told him about the need to have it out of a case and he said he never heard anything about that until I mentioned it to him.
    Also, although it will charge on the pad, it charges faster if I use the micro usb cable plugged into the power outlet the console.
  2. Oct 13, 2018 at 5:37 PM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    My 2017 trd sport has the charger as well. My Iphone 6s doesnt have wireless charging built in but i bought a mophie case and it works great with the trucks wireless charger. I do long drives and the qi charger is a great option when im streaming blue tooth for 5-6 hours constantly
  3. Oct 13, 2018 at 5:38 PM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    My 7 and 8 both charged fine on mine. I rarely use it though. Charges faster on the cord for me.
  4. Oct 13, 2018 at 9:43 PM
    Fatty Msclimm
    Fatty Msclimm Well-Known Member
    Fatty
    2018 DCLB TRD Sport Cement
    I uhh...peeled the stickers off. Does that count?
    I have a Samsung Galaxy S7 edge with some shitty case on it in my 2018 Sport. I have to place the phone with it pressed against the passenger side wall of the charge pad and pulled against the wall closest to the gear shifter for it to work. Hopefully that helps.
  5. Oct 13, 2018 at 10:25 PM
    tacos4cheap
    tacos4cheap Well-Known Member
    Los Angeles, California
    it has a lot to do with heat. when I charge with map on it will stop. When charging with screen off everything is okay
  6. Oct 13, 2018 at 10:39 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I understand you want it to work, cause after all you did pay for it. In all honesty though the thing charges incredibly slow and is finicky with phone placement. you’re better off going the USB route, which also charges pretty damn slow but marginally faster.
    Jim1946 and Fatty Msclimm like this.
  7. Oct 14, 2018 at 5:44 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Mine has started to overheat when leaving my phone on it for long drives(note8). Makes a crazy beep sound unlike any other warning I've heard from the truck. Really confused me the first couple times. Now I realize the rubber cover has expanded and bubbled in the middle. Not sure which is the cause and which is the result. Going to dealer in not too distant future
  8. Oct 14, 2018 at 6:07 AM
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    I bet it's either your case or the placement on the charging pad.
    My iPhone 8+ works but charging is VERY slow and it took me a while to get it to work. It will only charge outside of the case (I use a genuine Apple leather case) and it needs to be ALL the way to the right rear of the pad with the home button facing the driver side. If I jam on the brakes or if the phone otherwise moves any little bit out of that right rear corner, charging will stop. At best, with no running apps, I bet maybe 15-20% charge per hour of charge time.
    I just use a charging cable anymore. The wireless charging is nothing more than a poorly executed novelty IMO.
  9. Oct 14, 2018 at 6:26 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Mine works perfectly with an iPhone 8 in a Spigen case. I don't think it's as fast as a cable, but it did charge it up by 10% on a 30 minute drive.
  10. Oct 14, 2018 at 7:08 AM
    Vanderjdm
    Vanderjdm Well-Known Member
    2018 Off Road
    5% Tint, ARE V-Series w/ Yack Rack, Ebay Grill, Emblem Black Out Kit, Bumpershellz, Predator Tube Steps, Radioknobs by Tacowiede, Kicker Speaker Upgrade
    Yes. With mine it has to be situated in a very particular location, front left corner. Anywhere else and it doesn't work. When I do use it my phone gets hot as hell so I actually don't ever use it.
  11. Oct 14, 2018 at 7:08 AM
    Vanderjdm
    2018 Off Road
    That's lame. I think Toyota requires them to demo some of these basic features.
    Spare Parts likes this.
  12. Oct 14, 2018 at 7:11 AM
    Vanderjdm
    2018 Off Road
    That's exactly where I have to put mine. Won't work anywhere else.
    ozpall likes this.
  13. Oct 14, 2018 at 7:14 AM
    Thebush121
    Thebush121 Active Member
    I had to place my s9+ as far to the left as I could.
    TRDPro916 likes this.
  14. Oct 14, 2018 at 8:18 AM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I charge my old S4 with an add-on wireless charging receiver. Got pretty hot the other day during an extended drive. Seems pretty easy to get it positioned though. May have more to do with size/placement of the receiver than the charger...
  15. Oct 14, 2018 at 8:34 AM
    #35
    Trail Limo
    Trail Limo Well-Known Member
    It works on mine with an s9 but is finiky on placement, charges super slow, and the phone gets really hot. Heat is the killer of batteries so I don't plan on using mine. I recommend thinking of the wireless charger as a gimmick and use a cable instead
    Vanderjdm likes this.
  16. Oct 14, 2018 at 8:40 AM
    #36
    vytec
    vytec Active Member
    Gregg
    Austin, TX
    2018 Tacoma TRD Pro
    A.R.E CX Shell, Warn Hidden Winch, SmittyBuilt X20 Waterproof 10K Winch, BedSlide, LED Tail Lights, LED Headlights, More mods to come.
    My wife and I have iPhone X's and she has a case on hers and I don't on mine. Both charge fine. I do find that they do get quite warm when they are charging via this mode though. Not sure that it's that good for it.
  17. Oct 14, 2018 at 9:04 AM
    #37
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    So it works well with the mophie case? That’s good to hear, I’m very happy with my 7+, and don’t want to upgrade yet. The battery is getting weaker too. So I can kill 3 birds with one stone! Get better battery life, keep my current phone, and use a feature of my new truck that I thought I wouldn’t use for another couple years.
  18. Oct 14, 2018 at 9:27 AM
    #38
    jeeptec
    jeeptec [OP] Active Member
    Eric
    2018 Metallic Grey 4door
    I size up tire
    Thanks for the input and ideas.
  19. Oct 14, 2018 at 9:55 AM
    #39
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    My iPhone 8 Plus charges fine on it even in its case. You do have to have it in just right spot though...the front left quadrant of the charging area.
  20. Oct 14, 2018 at 11:06 AM
    #40
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    If I am the service manager I would tell my team that you are entitled to a resolution just like everyone else. I would check the vehicle in, issue a ticket etc.
    If your service manager expects less of his team then go around him/her.
    Spare Parts[QUOTED] likes this.
