quad pulling different directions
Discussion in 'All Terrain Vehicles' started by HeadlampRevamp, Nov 12, 2010.
  1. Nov 12, 2010 at 8:58 AM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    So I finally got around to working on my 1996 Kawasaki Bayou 220. It has been sitting for 5 years. I noticed that it will pull to the right or the left when braking. I'm wondering if this is a tie rod or shock issue. The shocks are not leaking and appear to be in good shape, so I'm assuming it has to be the tie rods.
    Does anyone know if I can tell if my tie rods are bad just by visual inspection?
  2. Nov 12, 2010 at 9:19 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What kind of brakes does that thing have? If they're hydraulic, bleed them, if not adjust them manually. As far as the tie rods, with the quad not moving, move the handlebar slightly side to side, how much play to you have (there shouldn't be much). You can check the alignment roughly using a tape measure, it should get you close enough for an ATV (disclaimer, don't do this for your truck, you can't be nearly precise enough). Lastly, check your tire pressures and make sure they're even side to side. Pressure differential front to back won't make a difference.
    Edit: that's an old and light ATV that doesn't have braking control like a car. Some of it could just be caused by the tires grabbing at different times assuming you're on a loose surface.
  3. Nov 12, 2010 at 9:23 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    sounds like an alignment issue to me
  4. Nov 12, 2010 at 9:30 AM
    Pugga
    Massachusetts
    F-150 Mod
    I thought that but he said only when braking and it pulls different directions. My neighbor had one of those and they're squirrely when they're brand new because they're so narrow and light. Any off camber and they pull hard when braking. Good thing is it's simple to check through all the stuff I listed within an hour, there's not much to those ATV's.
  5. Nov 12, 2010 at 9:30 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    If you are riding and let go of the handle bars what does it do? If it pulls then it is your steering, if it only pulls when you hit the brake then it is your brakes.
  6. Nov 12, 2010 at 9:38 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    The pulling occurs on all surfaces, including pavement. This is not something that happened before it sat for a couple year when I used to ride it, so I know there is an issue of some kind.
    I think if it was an alignment issue it would only pull to one direction. When slowing down, it pulls to whichever side the steering wheel is favoring.
  7. Nov 12, 2010 at 9:39 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Good point, it will pull to either direction if I let off the gas and no brakes are applied. Thinking tie rods for sure now.
    Do busted shocks have the same symptoms?
  8. Nov 12, 2010 at 10:02 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Brakes by cable, no fluid involved
  9. Nov 12, 2010 at 10:02 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I've checked the brakes and they don't appear to be sticking
  10. Nov 12, 2010 at 10:24 AM
    Pugga
    Massachusetts
    F-150 Mod
    A busted shock can cause symptoms but I don't think it'd be as severe as you're talking about. How much play do you have with the steering rack? Your brakes could be warped also after sitting for that long. I'm assuming they're disc brakes brakes? How about adjusting the brakes to make sure both sides are grabbing at the same time?
