Red Bullet VVTi Solenoids GB (Primary GB CLOSED)
Discussion in 'Automotive Group Buys' started by 12TRDTacoma, May 14, 2021.
  1. May 14, 2021 at 5:41 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    For those wanting some performance out of their VVTi system, these solenoids show some promise. Myself and @SUMOTNK have been pulling some strings and been in talks with Red Bullet Solenoids and have a potential group buy in the works. At the time of this writing there is no limit on how many folks can be in on the group buy, but once the buy is on be aware if you are further down the list you may be limited and have to wait until the next GB wave. Information has changed a bit, but just know that if these work out favorably, then distribution of these solenoids may make it stateside for quick and easy access. :thumbsup:
    Notable power gains in the mid range power band have been noted, driveability issues have been resolved, and as an unwarranted side effect, fuel economy is higher than before. Your mileage may vary based on usage, and weight of your truck.
    Benefits come in form of additional torque under the curve. Low and mid range powerband gets a nice kick from this.
    The downside to this as with any performance item comes with the price. However, it's a great replacement solution for those having VVT solenoid issues much like myself which emanate themselves in various ways (intermittent or frequent hard to start issues, cold engine misfire issues, and hesitation at take off from idle or low speeds, or direct VVT related codes)
    Couple these solenoids with the tuning power of HPTuners and you have an absolutely STELLAR platform to make the most of your potential power output.
    FAQ:
    - Will these require I pull my intake manifold or supercharger to replace? NO, just remove your throttle body and slide it to the side.
    - How long does it take to replace these? It depends on whether or not your engine is cold, on cold engines I would say about 20-30 minutes at most. On hot engines slightly longer due to the potential burn your fingers and hands factor because of the bolts relative location to the coolant manifold.
    Photo below of location:
    - Are these plug and play? Is anything else required? Yes it is plug and play, and while nothing else is required, in order to optimize them for maximum effectiveness, I do recommend HPTuners.
    - What gen are these for? 2nd gen only. It is unknown if these are direct replacements for the 3rd gen Tacoma at the time of this writing. 3rd gen guys will have to study and research their solenoids on their own in order to know if they are the same part number and design as the 2nd gens.
    Pricing as of right now comes in at $300 for a pair of solenoids (2). @SUMOTNK is handling the group buy participants with payment and shipment/ pick up of solenoids, so if any question, feel free to post here or message him. The 1GR engine is single VVTi so only two will be needed.
    1. 12TRDTacoma (me) - FULFILLED/ Not part of initial 40 for GB
    2. @Jimmy92870 PAID
    3. @mulisharydr PAID
    4. @ARoman83 PAID
    5. @prise
    6. @dib PAID
    7. @Bfz777 PAID
    8. @sf.larry PAID
    9. @White lightning boosted PAID
    10. @scootter82 PAID
    11. @nudavinci64 PAID
    12. @henryp PAID
    13. @Scott B. PAID
    14. @blackenblue PAID
    15. @zerotimeouts PAID
    16. @Sterling_vH111 PAID
    17. @MuddySquirrel PAID
    18. @ajohnson PAID
    19. @04TacoRunner PAID
    20. @Kini PAID
    21. @Iceman710 PAID
    22. @Athlaos PAID
    23. @Shadowhunter PAID
    24. @alvinfromhawaii PAID
    25. @Supra4x4 PAID
    26. @XPOTRPR PAID
    27. @MurderedTacoV2 PAID
    28. @TheFang PAID
    29. @TodayWasTHeDaY PAID
    30. @zippsub9 PAID
    31. @tinker_troy PAID
    32. @Murphinator PAID
    33. @NLMOOmar PAID
    34. @Hawk373 PAID
    35. @1slow4.0 PAID
    36. @JacksonTacoma PAID
    37. @garciav PAID
    38. @Biscuits PENDING
    39. @kasnerd PAID
    40. @racebug68 PAID
    41. @point45 PAID
    _________________________________________
    CUTOFF as of the time being, a 2nd round group buy is unconfirmed, but the pending list for said group buy has the following members on reserve:
    1. @greenEFSI
    2. @mk5
    3. @TacoTuesday1
    4. @AllTacosFloat
    5. @Key-Rei
    6. @T.Barn
    SPOTS ARE RESERVED TO A LIMITED AMOUNT OF 40 AT THE TIME OF THIS WRITING (12/1). MY NAME IS INCLUDED IN THIS GB BUT I HAVE BEEN FULFILLED SO THE LIST CAPS AT 41 as I am not a part of the initial 40. AFTER THAT, THIS GB WILL BE CLOSED UNTIL FURTHER NOTICE. PLEASE SEE PAGE 22 POST 434 FOR LATEST UPDATE.
    NOTE: Please see this link for the latest update on current results:
    https://www.tacomaworld.com/threads/red-bullet-solenoids-feeler-gb.721327/page-4#post-26155805
  2. May 14, 2021 at 6:20 PM
    elmontemike
    elmontemike Well-Known Member
  3. May 14, 2021 at 7:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Me. For at least one set
    12TRDTacoma[OP] likes this.
  4. May 14, 2021 at 7:19 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  5. May 14, 2021 at 7:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Added. :thumbsup:
  6. May 14, 2021 at 10:29 PM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Do both sets have to be installed or can I get away with only one set to get the performance boost?
  7. May 14, 2021 at 10:44 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  8. May 14, 2021 at 11:51 PM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Count me in
    RedZeppelin and 12TRDTacoma[OP] like this.
  9. May 14, 2021 at 11:52 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    We'll only need one set.
  10. May 15, 2021 at 1:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You have been added good sir.
  11. May 17, 2021 at 10:01 AM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    how hard is it to swap these in ?
    scootter82 likes this.
  12. May 17, 2021 at 9:17 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    In the beginning stages of a supercharger rebuild atm. Would def be down for buying the first set. Possibly exhaust side.
  13. May 18, 2021 at 8:02 AM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Will this be beneficial to N/A with the intention of adding SC down the road?
  14. May 18, 2021 at 9:11 AM
    SUMOTNK
    Eddie
    Yes, I would think so. A lot of the applications for these modified solenoids are for NA or hybrid engines. Strangely, a segment of the Prius crowd has a favorable opinion on these solenoids.
  15. May 18, 2021 at 9:29 AM
    ARoman83
    Alex
    Wisco
    Only legal stuff
  16. May 18, 2021 at 10:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Added buddy. :thumbsup:
    ARoman83[QUOTED] likes this.
  17. May 18, 2021 at 5:10 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    So $500 is already the posted sale price. What are you hearing for a discount on top of that?
    SUMOTNK likes this.
  18. May 18, 2021 at 7:10 PM
    who done it
    who done it Member
    Raleigh NC
    4runner
    I'm in for a set.
    12TRDTacoma[OP] and SUMOTNK like this.
  19. May 19, 2021 at 4:38 PM
    dib
    dib Well-Known Member
    Gary
    Escondido, CA
    11 TX Pro
    Camburg LT and Magnuson Supercharger
    I'm definitely in.
  20. May 19, 2021 at 4:45 PM
    SUMOTNK
    Eddie
    Will update this thread soon. But I've been working with @12TRDTacoma on where to steer this item and GB.
