quart low each oil change
Discussion in 'Technical Chat' started by stratton, Jul 14, 2010.
  1. Jul 15, 2010 at 8:33 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Thats kind of odd that you're burning a full quart each oil change. Although I do not have the same engine, I have the 2.7, It shows absolutely no sign of any oil loss after each change @ 8k mile oil change intervals. I'm running Royal Purple 5w-20
  2. Jul 15, 2010 at 11:12 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Engines burn oil. New, used, doesn't matter. Some burn more, others burn less. Some of it depends on how the engine was broken in. Some of it depends on engine design and operator usage.
    Blue smoke=bad:)
  3. Jul 15, 2010 at 10:56 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    http://www.mototuneusa.com/break_in_secrets.htm
    Yes I agree -- break-in! Very important to seat the rings. And yes all engines consume oil.
    See above
  4. Jul 16, 2010 at 3:35 AM
    stratton
    stratton [OP] Well-Known Member
    I have a buddy that races mods and of course works on them. He swears by this method of breaking in new engines. I always thought he was nuts for saying that you need to run a new engine hard to break it in. He will like to hear that he was right on this one. I took the first thousand miles really easy with my truck. I should have romped on it.
  5. Jan 5, 2013 at 10:36 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have a 2010 prerunner and for the past few oil changes I have had that issue as well.. I think I am going to try checking it at 3k then change it at 5k to see if there is a huge difference. this oil change I did today I did an additive to the oil .. so I will see if that doesn't help as well
  6. Jan 5, 2013 at 10:46 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I would run a fuel system cleaner through it 1 week before then at oil change run Gunk crankcase cleaner for 5 minutes to maybe free up any sticking piston rings then change the oil out to Mobil 1 0-20 synthetic.
  7. Jan 5, 2013 at 10:50 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    I did the fuel system cleaner today
  8. Jan 5, 2013 at 2:40 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Also replace your PCV valve. High crankcase pressure will force oil past the rings.
