Question about 2002 wheels on a 2012
Discussion in 'Wheels & Tires' started by JWinTN, Sep 1, 2012.
  1. Sep 1, 2012 at 9:07 PM
    JWinTN
    JWinTN [OP] Well-Known Member
    E TN
    2012 TRD Off Road
    I have a 2012 DCSB OR and have been looking at changing the look a bit.
    I ran across these wheels on CL: http://tricities.craigslist.org/pts/3244182520.html I like the looks of these wheels, and for that price, I could refinish them and still not be out too much money.
    I have a few questions. First, will these wheels even work on my truck, and is that a decent price? Second, will I have TPMS problems? Third, what should I look out for when purchasing used wheels? These look like they've seen some better days.
    I'm completely ignorant about this stuff, so any help would be appreciated.
  2. Sep 1, 2012 at 9:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They will fit.
    The offset looks a little light... tires might stick out more than you'd like.
    Your TPMS sensors will transfer to the other wheels.
    That's my biggest concern.
    They could be out of round or the hubs might be bent, there could be cracks in the spokes.
    Of course, cosmetically, corrosion and pitting are always an issue with alloy wheels that haven't been cared for.
    Those are not Toyota factory wheels... those are aftermarket, look like Superior. I'm possible to date from the photos, but from the style and font of the letter on the centercap, I'd say those wheels are much older than 2002.
    Maybe 1992.
  3. Sep 2, 2012 at 5:03 AM
    JWinTN
    E TN
    2012 TRD Off Road
    Sound like a good set to pass up. I thought they were factory or I likely wouldn't have looked at them at all.
    Thanks for the info.
  4. Sep 2, 2012 at 5:07 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Those are Enkies. They were added as a port option and sold as OEM wheels.
    They are nice wheels.
    They are definitely not from 92. They started showing up sometime in the early 00's.
    If you like em, go for em!
  5. Sep 2, 2012 at 10:36 PM
    JWinTN
    E TN
    2012 TRD Off Road
    Guys, I really appreciate the replies.
    Well, that's interesting. From what I can dig up, they are Enkei Brawns, but I can't find any specs on them. Listed as a package option on down the page here: http://www.portcitysuzuki.com/specs-and-photos-packagesoptions-toyota-tacoma-2002-101996.html
    Again, I'd like to somewhat personalize my truck, but not at great cost (other expensive hobbies), but I don't want to reduce the performance or reliability.
    Are my stock wheels a better option than these, all things considered? I'm ambivalent about the looks of the stock ones, but they're a pain to clean. Further, I'd like to change the color but would prefer to keep the stock parts as is in case I ever want/need to go back to stock.
    I figured I could grab these and refinish them and not have too much money into getting a different look, but not if they are going to be radically different from stock as far as backspacing (of which I have only a basic understanding) and other such particulars.
    So, coming from my position, where I have only a passing fancy to make a change and not a pressing need—do you think I should pick these up or stick with the stock wheels?
    Again, thanks for the help, and all opinions are welcomed as well. If you think the wheels are wretched and no one but a fool would do that to their truck, I'd like to hear that too.
  6. Sep 2, 2012 at 10:49 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Most Taco owners prefer the wheels sticking out ~1 inch further (it gives the truck a wider stance). With stock size tires, you won't run into tire clearance issues.
    These wheels will have similar pitfalls as any other 10 year-old wheels that haven't been meticulously cared for. There can be slow air leaks at the bead (losing 1 psi per week is not uncommon), so you have to pump up the tires more often. Watch for cracks and bent rims.
    Truck modding if done correctly, usually isn't cheap.
    40% of TW members spent at least $2000 in mods
    4% spent over $10,000
    http://www.tacomaworld.com/forum/technical-chat/1883-tacoma-mods-how-much-have-you-spent.html
  7. Sep 2, 2012 at 10:58 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  8. Sep 2, 2012 at 11:01 PM
    KenLyns
    Belly of the Beast
    So actual spending is higher? :laugh:
  9. Sep 2, 2012 at 11:04 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Imagine that :D
  10. Sep 3, 2012 at 1:33 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    1st Gens have 4.5" BS 2nd Gens have 5.25" BS so 1st Gens on a 2nd Gen will stick out .75" more.
    255/85/16 BFG KM2s on 1st Gen TRDs
    245/65/16 Dungflops on stock steelies
  11. Sep 3, 2012 at 6:43 AM
    JWinTN
    E TN
    2012 TRD Off Road
    I think I'm going to pass on these and avoid the pitfalls and hunt something newer or at least something that's seen better care.
    And I don't know if caps count as a mod, but between the Leer 180, the DO Rock Crushers, and the little things (Weathertech mats, etc.) I'm over the $2,000 and heading on up.
    Thanks for the guidance, gentlemen.
