Question about 4 Lo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lars, Jun 13, 2015.
  1. Jun 13, 2015 at 9:46 PM
    Lars
    Lars [OP] Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Is it normal for the truck to beep constantly while the truck is in 4 Lo or should I take it to go get looked at?
  2. Jun 13, 2015 at 9:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If it's beeping , it's not engaged in 4LO
  3. Jun 13, 2015 at 9:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^This.
    Are you sure 4lo is engaged? Truck would be moving at less than half the normal speed.
    If truck is not in Neutral when you shift into 4lo, it will beep.
  4. Jun 13, 2015 at 9:51 PM
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
    Go to a complete stop and put it in neutral then engage 4Lo
  5. Jun 13, 2015 at 9:51 PM
    Lars
    Lars
    Cedar Creek, TX
    Yes.
    Sounds like I didn't use 4Lo at all today then.
    I'll check in the morning to see if it will go into 4Lo. Thanks!
  6. Jun 13, 2015 at 9:52 PM
    Lars
    Lars
    Cedar Creek, TX
    Yes.
    I was in Park, when I turned the switch. I suppose I should have consulted the manual more carefully....
  7. Jun 13, 2015 at 9:53 PM
    OZ-T
    Peter North
    British Columbia
    It's on the driver's side visor too
  8. Jun 13, 2015 at 10:05 PM
    Pigpen
    Dan
    Northwest Montana
    Mine is often obstinate about engaging
  9. Jun 13, 2015 at 10:29 PM
    S and J
    S and J Well-Known Member
    Scott
    Las Vegas
    2015 AC SR5 Off Road Package
    Have to be in neutral for it to engage. Same with the locker. If either had beeping then they have not engaged yet. Also if you lock your truck with the key fob before closing all doors, it will beep and then not lock the doors. Why? Idk...
  10. Jun 14, 2015 at 12:11 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Mine beeps in 4 Low. I only use it to get up on ramps when I change oil or do some maintenance.
  11. Jun 14, 2015 at 12:18 PM
    OZ-T
    Peter North
    British Columbia
    If its beeping , you're not in 4LO
  12. Jun 14, 2015 at 2:01 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    ^that
  13. Jun 14, 2015 at 2:09 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I had the same problem until I realized you have to push the clutch in to switch to low range. Read the visor and figured it out.
    So if you have a manual that's your problem.
  14. Jun 14, 2015 at 2:43 PM
    JBecker
    Virginia
    Yeah I found it doesn't want to engage the front diff unless it's spinning.
  15. Jun 14, 2015 at 2:49 PM
    Lars
    Lars
    Cedar Creek, TX
    Yes.
    Thanks for the tips y'all. I am dumb, and when I followed instructions (neutral, and stationary) it went into 4 Low no problem at all, and no beeping.
