Question about 4wd operation
Discussion in 'Technical Chat' started by Badwin45, Jul 7, 2010.
  1. Jul 7, 2010 at 4:57 PM
    Badwin45
    Badwin45 [OP] Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    After lurking around I think I have a good idea of how the VSC/Auto-LSD work but I still have a couple of questions about the operation of my 2010 DC 4x4 (SR5 package):
    1) Is the front differential "open"?
    2) Why would it require more throttle input when making sharp turns in 4wd? It feels like the truck is trying to push through the turn. I don't recall my last 4x4 doing this. (of course that was 18 yrs ago...)
    Thanks,
  2. Jul 7, 2010 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ffront is an Open diff. The drive train binds when turning in 4 wheel drive. Its normal. Dont use 4 wheel drive on pavement/concrete.
  3. Jul 7, 2010 at 5:08 PM
    Badwin45
    OKC
    So in 4H I essentially have 2 open diffs?
    Hooray :(
  4. Jul 7, 2010 at 5:11 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    no you have auto lsd front and rear in 4hi. Essentially you have LSD front and rear.
    The diffs are open, but when one tire spins the brakes are applied to that wheel to transfer power to the other tire.
    not like a clutch type mechanical LSD but same concept. instead of internal clutch it uses the brakes to transfer pwer
  5. Jul 7, 2010 at 5:14 PM
    Yoytoda
    Roland
    completely stock
    ^^^^BINGO^^^^
    on another note, follow the 4lo trac in my sig to a how to on making TRAC work in 4Lo. LSD front and rear in 4lo...unstoppable
  6. Jul 7, 2010 at 6:15 PM
    Badwin45
    OKC
    Thanks guys, I think this is starting to make sense...
    I believe the problem is that I took 3 years of latin in high school and the manual is written in greek.
    Let's see if I have this straight.
    In 2wd, the rear diff is open unless I engage Auto LSD.
    In 4wd, Auto LSD is ON thus giving me a virtual LSD.
    whippersnapper02: Thanks, that makes sense.
