Question about 5100s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMC37, Jun 1, 2018.
  1. Jun 1, 2018 at 4:50 PM
    BMC37
    BMC37 [OP] Active Member
    Brett
    2017 Quicksand TRD Sport
    I just recently installed 5100’s on the front end of my 3rd gen. I set them on the third notch which is 1.1” of lift but somehow gained 2” and now I’m 1” higher in the front than the back. Does that normally happen or am I missing something here?
  2. Jun 1, 2018 at 4:57 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Did you get the second gen 5100s? Are you using your stock coils?
    Edit: Looks like the second gen 5100s provide 1.75” of lift on second notch. Also, new coils could lift more l, or wait for the suspension to settle out a bit. Take it around town, hit a few speed bumps kind of hard.
  3. Jun 1, 2018 at 5:04 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    What coils are you using?
  4. Jun 1, 2018 at 5:07 PM
    BMC37
    Brett
    I’ve got the 3rd gen 5100s and stock coils.
  5. Jun 1, 2018 at 5:25 PM
    jmauvais
    NorCal
    ...stuff
    Maybe it’s not the second perch, but the 3rd or 4th, they counted from the wrong side? I don’t know anything is possible.
  6. Jun 1, 2018 at 5:27 PM
    cookiesandvodka
    cookiesandvodka Well-Known Member
    I’m not sure which generation I got but mine are on the second notch, one above stock and its pretty level. Sometimes front looks higher depending on ground. I have stock coils and 5100 just in front.
  7. Jun 1, 2018 at 5:28 PM
    cookiesandvodka
    yea. Look under your truck at them. You should be able to see one ring notch showing.
  8. Jun 1, 2018 at 5:29 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    How long have you had them installed? If it was recently I would give a few weeks to a month to allow it to settle.
    Man of Steel TRD likes this.
  9. Jun 1, 2018 at 5:35 PM
    BMC37
    Brett
    The 3rd gen 5100s have 5 notches and I have them set on the one in the middle. I just got through installing them a few hours ago. I’m expecting some settling but I don’t think they would settle an inch.
  10. Jun 1, 2018 at 5:38 PM
    jmauvais
    NorCal
    ...stuff
    They could
  11. Jun 1, 2018 at 6:02 PM
    Fiend13
    Chad
    It’s gonna depends on how you drive it. If it’s all street and no off-road then they’ll settle but not as much if oh use it for trails and they take more a beating
  12. Jun 1, 2018 at 6:07 PM
    BMC37
    Brett
    I’ll take your word for it. I guess if they don’t I’ll just get new leafs or something to raise the rear an inch.
  13. Jun 1, 2018 at 6:40 PM
    jmauvais
    NorCal
    ...stuff
    Safe bet. Hope it settles out for you
  14. Jun 1, 2018 at 6:42 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Is the spring seat oriented correctly?
  15. Jun 1, 2018 at 7:02 PM
    BMC37
    Brett
    Yes it is. The bottom of the spring lines up perfectly with the ramp on the spring seat.
  16. Jun 2, 2018 at 6:46 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    That... ^^^ Get some progressive AALs from @HeadStrong Off-Road will give you a little lift and stiffen up that ride a little. While yer there get the 5100s for the rear. Oh and then you need to re-adjust & level the fronts so may as well get new springs up there too.
    The Sport suspension really is a dog bro, just sayin.
    HeadStrong Off-Road likes this.
  17. Jun 2, 2018 at 8:06 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A less expensive option: Leave the front as is (I did the same exact thing as you) and just put a single Deaver leaf and a set of 5100’s in back, and keep the overload leaf in. @HeadStrong Off-Road recommended this for mine and I couldnt be happier with it. Overall lift was 1.5” front and back after it all settled.
  18. Jun 2, 2018 at 8:24 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    OR that ^^^ Get rid of the Sport shocks all around they are hideous.
  19. Jun 2, 2018 at 8:44 AM
    Ballinbosox
    Ballinbosox Well-Known Member
    Andrew
    2017 Toyota Tacoma TRD Sport White
    Single aal with stock overload
    bobrown14 likes this.
  20. Jun 5, 2018 at 7:10 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much for your recommendation @bobrown14 we truly appreciate it! :fistbump:
