question about a couple bolts...
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, Aug 24, 2009.
  1. Aug 24, 2009 at 6:56 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    So I have noticed my truck getting a great deal louder in the exhaust department and my cel has been on for a while. Well I just noticed that my rear sensor is missing both of its bolts holding it in place and its sitting loose in the whole. Anyone know what size bolt it is? Is it possible that this is the cause of my cel? btw its a 2.4L
  2. Aug 24, 2009 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That more than likley is the cause of your CEL. No idea on the size, though.
  3. Aug 24, 2009 at 7:02 PM
    emglishe30
    NJ
    i couldnt believe it when i saw there were no bolts...hows this happen?
  4. Aug 24, 2009 at 7:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    Bolts or nuts?
  5. Aug 24, 2009 at 7:06 PM
    emglishe30
    NJ
    good question..whatever would hold the sensor in place..
  6. Aug 24, 2009 at 7:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    My 98 had nuts that rusted off. Let me run out in the garage quick.
  7. Aug 24, 2009 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bolts.
  8. Aug 24, 2009 at 7:11 PM
    emglishe30
    NJ
    sweet thanks
  9. Aug 24, 2009 at 7:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    M8-1.25
  10. Aug 24, 2009 at 7:16 PM
    emglishe30
    NJ
    you the man...hope this solves my problem
  11. Aug 24, 2009 at 7:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    You can get the bolts at your local hardware store. I also recommend lock washers and a gasket. It may take a few miles before the CEL goes away.
  12. Aug 24, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lock tite. No lock washers. X2 on the new gasket. :)
  13. Aug 24, 2009 at 7:51 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    i that has happened to my truck the rear heater o2 sensor bolts were broken.
  14. Aug 24, 2009 at 7:52 PM
    98tacoma27
    Ben
    Not Beech Creek
    I don't like using Loctite in a hot environment.:p
  15. Aug 24, 2009 at 8:06 PM
    emglishe30
    NJ
    Sweet, I was planning on going to advance auto after i get the bolts on and have them clear the cel..
  16. Aug 24, 2009 at 8:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    Just pull the ECU fuse for a few minutes. Saves a trip.
  17. Aug 25, 2009 at 1:14 PM
    emglishe30
    NJ
    well I got the nuts I needed, sprayed the bolt with a little wd-40 and got one nut on but the other one jammed up and stuck on the bolt. At least the exhaust leak is gone. Weird thing is that the cel has been on for quite some time and before I even put the nut on and secured the sensor, the light was not lit up anymore.
  18. Aug 25, 2009 at 5:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    Maybe the light blew? :notsure:
    :D
  19. Aug 25, 2009 at 8:07 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    back the other one out and clean up the threads with a thread file man. That should do the trick!
