Question about a limited slip rear dif
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFMS, Feb 9, 2011.
  1. Feb 9, 2011 at 11:01 AM
    TacoFMS
    TacoFMS [OP] Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I have a 08 v6 prerunner. just the sr5 edition not trd. i know that this makes me a one wheel wonder. I was wondering what options i have out there to see about getting a limited slip set up for my truck. I know everyone will yell do a search but im at work and cant use the time needed for a search. does someone make a kit, can i use parts from a junkyard do i have to do electrical work with it, i know that in old chevy's you just pop open the diff and add a lil here and a lil there and you have a limited slip. just wondering if someone could tell me what i need to do. thanks in advance.
  2. Feb 9, 2011 at 11:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    TRD has an ls diff. Also, consider tje Detroit Tru Trak. Its a solid LS.
  3. Feb 9, 2011 at 11:18 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you find one of the mechanical Limited slipps from 2005-2008 trucks that would be good, But last time I check there were only 4 available in US :notsure:
    I had been looking for one on the cheap but so far no luck.
    Trutrac is another option but trutrac does not work with one wheel i n the air so not sure if you want that.
  4. Feb 9, 2011 at 11:29 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    sorry for the thread jack but does my 08 TRD sport have LSD? it has the sticker on the rear end
  5. Feb 9, 2011 at 11:32 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    If it has the sticker for LSD oil then yes you have a mechanical LSD.
  6. Feb 9, 2011 at 11:54 AM
    TacoFMS
    Justin
    Louisa County, VA
    so where or how would i go about finding a mechanical set up for it. like a store taht sells them or something? or go on a junkyard run or can i pick up the parts needed at toyota?
  7. Feb 9, 2011 at 12:02 PM
    TacoFMS
    Justin
    Louisa County, VA
    ok so now to just try and brace myself for how much its gonna cost.
  8. Feb 9, 2011 at 12:10 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I have a 2005-2008 TRD LSD sitting in my garage... I have yet to install it... :laugh:
  9. Feb 9, 2011 at 12:11 PM
    TacoFMS
    Justin
    Louisa County, VA
    thank you so much whipper, I was just getting ready to ask you if you knew of any good shops that i could contact. not really any around here i would trust. what exactly would be included in the "whole3rd member"?
  10. Feb 9, 2011 at 12:18 PM
    BlueT
    NorthEast
    The factory original new with carrier ready to swap is around 2K :eek:
    The few I saw on the junkyards were little over $1K with small mileage to $650 with crap load of mileage.
  11. Feb 9, 2011 at 12:19 PM
    TacoFMS
    Justin
    Louisa County, VA
    where did you find yours at? if you dont mind me asking
  12. Feb 9, 2011 at 12:55 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    bought it used one here
