Question about All-Terrain Tires
Discussion in 'Wheels & Tires' started by whiting1977, Mar 5, 2024.
  1. Mar 5, 2024 at 10:20 AM
    whiting1977
    whiting1977 [OP] Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    I drive a 2014 Prerunner and obviously do not go off-roading in it. I do however drive a lot of mountain roads including wet and gravely roads. Would I benefit from a set of AT tires or are those strictly/mostly for off-roading?
  2. Mar 5, 2024 at 10:34 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    All Terrain tires are a compromise between a street tire and a true off-road tire. If you do any driving on unimproved roads, I'd be using an All-Terrain. How aggressive the tires are vary a LOT. Some are much closer to a road tire, others closer to a true off-road tire.
    For what you're doing I'd stay away from a LT (light truck) tire. They are really designed for 3/4- and 1-ton trucks. But they are a tougher tire that a lot of guys use on smaller trucks an SUV's if they are hard core. Stay with something moderately aggressive in a P or standard load tire and you'll be fine.
    There are some downsides. They cost more, the tires may be a little louder, they may not ride as smooth, and they may wear out sooner. It is also important to rotate them more often than street tires.
    TheWildMan likes this.
  3. Mar 5, 2024 at 10:44 AM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    Thanks for the advice. Much appreciated. I was considering the Toyo Open Country AT 3s.
    MGMDesertTaco likes this.
  4. Mar 5, 2024 at 1:53 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    The Toyo Open Country AT3 is a solid option for what you are looking for.
  5. Mar 5, 2024 at 2:14 PM
    perterra
    perterra Well-Known Member
    Tejas
    Damn good tire.
  6. Mar 5, 2024 at 2:23 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I just put on a set of @Discount Tire Pathfinder AT I had Nitto G2s and I can
    Say the Pathfinder is great. Road manners are excellent, traction great, wet road manners excellent, quiet tire yet aggressive enough for the gravel roads to the trails and campsites. Priced well too. Very very pleased.
  7. Mar 5, 2024 at 2:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Michelin Defenders
  8. Mar 5, 2024 at 2:54 PM
    Discount Tire
    Arizona, USA
    Thank you for your business, we appreciate you support. We are glad the Pathfinder is meeting your expectations and you are happy with them.:thumbsup:
  9. Mar 5, 2024 at 2:57 PM
    MGMDesertTaco
    Another vote for Toyo open country at3's.
  10. Mar 5, 2024 at 3:02 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Definitely recommend the Toyos. Stick to SL/XL if you need better wet traction.
    whiting1977[OP] likes this.
