Question about bilstein front shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Oct 19, 2012.
  1. Oct 19, 2012 at 8:56 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys, Iam thinking of leaveling my 2011 DC Prerunner TRD with the Bilstein 5100 ftont shocks. My question is. How much lift do's the 0,85 setting give you and can I reuse my oem coil springs? I am not doing anything with the rear. Thanks for any info.
  2. Oct 19, 2012 at 9:14 AM
    BaconTaco
    BaconTaco Well-Known Member
    Nate
    Lancaster, CA
    06 DCSB TRD Sport silver prerunner
    secondary & Res Box delete, Kenwood DDX419 HU installed in metra 95-8214 and Xbox 360, Mobil 1 syn oil, Shortened stock antenna, 400w anytime mod with rear center console outlet, Debadged tailgate, tailgate anti theft clamp mod, immryo's rear view mirror re locator, post axle exhaust dump, Black TRD OR floor mats, TRD center caps, 265/70/17 BFG rugged terrains
    The .85 setting means it gives you .85 inches of lift on average. And then next settings are 1.75" and 2.5". Each truck is slightly different. And since you have a prerunner you will probably get a little more lift without the weight of the 4x4 system. I also have a prerunner and billies gave me 1 full inch from the .85 setting and 2 full inches on the 1.75 setting. I couldn't get a perfect level though so I chose rake over bro lean with the rake being only 1/4 inch I started with the 1.75 and then decided to drop down to the .85. Make sure you take measurements before an after so you know how much lift you got. Also in my case I think my rear springs are sagging a little.
    Here's my truck before
    And here's after the .85 setting
    The after was taken at night but you can still see the difference.
  3. Oct 19, 2012 at 11:51 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thank you for the info, Much appreciate! I red somewhere on here that I can'nt run my stock coils with the bilsteins becouse I have the TRD package
    is that true?
  4. Oct 19, 2012 at 11:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, it's not true. The TRD Off Road has progressive coils so they get substantially stiffer the more you preload them but there's no reason the 5100's won't work with either of the TRD packages.
  5. Oct 19, 2012 at 11:59 AM
    tacoma guy
    Joe
    Phoenix Az.
    Oh ok. Good to know. If I set them at .85 is it going to stiffen it to much?
  6. Oct 19, 2012 at 12:07 PM
    Pugga
    Massachusetts
    It'll be stiffer but shouldn't be uncomfortable by any means. You might even find that you like it better because of the reduced nose-dive under braking and reduced truck roll in corners.
  7. Oct 19, 2012 at 1:10 PM
    tacoma guy
    Joe
    Phoenix Az.
    Awesome, Thanks bud I appreciate all the input.
