Question about brake
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThoNgo, Apr 22, 2016.
  1. Apr 22, 2016 at 6:13 PM
    ThoNgo
    ThoNgo [OP] Member
    Hi there
    The brake pedal can not move up and down after engine turn off. Is this normal?
    Thanks
  2. Apr 22, 2016 at 6:17 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    That is not normal. How would you stop if your vehicle died while you were driving?
  3. Apr 22, 2016 at 6:21 PM
    Clearwater Bill
    Billy
    Largo Florida
    Weak legs?
    You loose power assist with the engine off, so you are manually (your leg) working the hydraulics. It is quite hard to compress, no toe tapping stuff gonna happen here.
    If the brakes work fine normally, I find it quite hard to imagine the pedal not being movable with the engine off.
  4. Apr 22, 2016 at 6:40 PM
    ThoNgo
    ThoNgo [OP] Member
    So, what problem is It? When the engine run I brake it ok
  5. Apr 22, 2016 at 6:44 PM
    ThoNgo
    ThoNgo [OP] Member
    No, It lock and I can not push down brake pedal when engine turn off. My foot is strong
  6. Apr 22, 2016 at 6:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sorry, not worth the safety risk to diagnose something like this on the internet.
    If no one shows up with a similar experience and solution, find a mechanic and get it sorted ASAP.
    Brake systems are not too complicated, but also they are too important to guess about.
    Please report back the cure for the good of the group.
    ajm likes this.
  7. Apr 22, 2016 at 7:04 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    you can only push your pedal an inch if the engine isnt running. the vacuum of the engine is supposed to make it a lot easier with the vacuum booster. if your engine dies and youre moving, you have to use your emergency/parking brakes. that's what theyre there for.
  8. Apr 22, 2016 at 7:09 PM
    ajm
    Anthony
    AZ
    1996 4x4
    I turn my truck off while rolling quite often and my brakes still function.
  9. Apr 22, 2016 at 10:14 PM
    ThoNgo
    ThoNgo [OP] Member
    I am not diagnose. I wonder how we can brake when the engine off. There are some good answer here, Thanks, so my truck brake function normally
  10. Apr 23, 2016 at 5:44 PM
    CodeSeven
    Serge.
    Coachella Valley
    yes the breaks will function with the engine off, but you still cant push the pedal down very far without vacuum assist. then again, your master cylinder may be bad as it may not be relieving all the pressure that is built when you press down on the pedal
