question about button????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by madcatter, Feb 19, 2010.
  1. Feb 19, 2010 at 1:43 PM
    madcatter
    madcatter [OP] Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    2010 double cab--under the steering column by the hood release there is a button---it has an icon that looks like the tire pressure warning light in the instrument cluster.
    what exactly is this and whats its purpose,i cant find it in the owners book
  2. Feb 19, 2010 at 1:46 PM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    :facepalm:
  3. Feb 19, 2010 at 1:47 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    resets the TPMS sensor for the tires
  4. Feb 19, 2010 at 1:53 PM
    madcatter
    western pa
    2010 tacoma
    why would that need reset?????i thought when pressure went down,the dash showed a warning icon.when air was put back in it went out,
  5. Feb 19, 2010 at 1:54 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    Rtfm!
  6. Feb 19, 2010 at 1:57 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    One word, manual
  7. Feb 19, 2010 at 2:04 PM
    madcatter
    western pa
    2010 tacoma
    i will search harder in the manual
  8. Feb 19, 2010 at 2:06 PM
    braggman7
    braggman7 Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    wouldnt it have been just as easy to tell him the answer as it was telling him to read the manual?
  9. Feb 19, 2010 at 2:08 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    You fill your tires to what pressure you want then hit the reset button and you are good to go
    don't forget the spare
    If some of you guys do not want to be here and post at least save the bs for another board
  10. Feb 19, 2010 at 2:08 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Probably, but too often on forums people expect to be spoon fed information that may be readily available before looking themselves.
    It would likely need to be reset when rotating tires and stuff like that so it doesn't think a tire is in a location that it's not.
  11. Feb 19, 2010 at 2:08 PM
    dog tired
    NE Ohio
    Yeah so why didn't you ?
  12. Feb 19, 2010 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It cant identify locations of tires. Just weather or not 1 is out of range with psi.
  13. Feb 19, 2010 at 2:12 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    if in any case you put bigger tires, the tire pressure must me reset depending on the size of the tire. i think, must be on the manual though....
  14. Feb 19, 2010 at 2:14 PM
    jtav2002
    Josh
    Reading, PA
    Gotcha, thanks for clarification. Wasn't sure how ours worked. The system on the Impala SS I had location based and showed you the PSI of all the tires. Which was nice, but when it came to reset it due to a rotation it was a pain in the ass resetting it you had to go around in a certain order to each tire and let out or put in a bit of air til it registered what tire it was.
  15. Feb 19, 2010 at 2:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....Many vehicles have the ability to identify which tire.....The Toyota systems are inexpensive ones.
  16. Feb 19, 2010 at 2:18 PM
    braggman7
    Athens, GA
    because i don't know the answer.
  17. Feb 19, 2010 at 2:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The reset button is to reset the already set pressure values it monitors. For example, If you normally run 35 psi in your tires, and you switch to a different set, and are going to run 30 psi, you reset the sensor so it doesnt trigger the air psi warning light. OR, if off roading, and you air down your tires, you can reset the light so its not iluminated while your off roading.
  18. Feb 20, 2010 at 5:55 PM
    madcatter
    western pa
    2010 tacoma
    thanks for the answer,,,i read the manula a few times one the subject and still was not understanding it.call me a dumbass.thanks for the help
  19. Feb 20, 2010 at 5:57 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    09+ dont have the sensor in the spare
  20. Feb 20, 2010 at 6:12 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    hahhaha! i can barely keep up with the acronyms as it is!! this is effen funny.
