Question about caps
Discussion in '1st Gen. Tacomas (1995-2004)' started by cashman, Jan 3, 2010.
  1. Jan 3, 2010 at 1:51 PM
    cashman
    cashman [OP] Member
    western pa
    01 xtra cab
    Hello, I'm new to the forums and have a question about a cap. I have an '01 xtra cab and have found a cap off a 95. The guy is about 2hrs away and he measured the cap at 76" by 60". I come up with 77" from the front outer edge of the bed to the back. So what I'd like to know is will a 95 cap fit on an 01. It is a fancier cap, the style that replaces the tailgate with the big "hatch" style and the smaller glass door in the center. thanks
  2. Jan 3, 2010 at 2:55 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Welcome to TW!
    I looked at that exact same cap if its the one off of Craigslist. As long as it fit on his 95 Tacoma extra cab then you should be just fine. But don't quote me on it. :D
  3. Jan 3, 2010 at 3:33 PM
    cashman
    cashman [OP] Member
    western pa
    01 xtra cab
    thanks, I was thinking that it would be ok, but just wanted to check and see if anybody knew for certain. and yes it is the one on craigslist, seems like a really good deal.
  4. Jan 3, 2010 at 3:35 PM
    Afwrestler1986
    Johnstown, NY
    I just didn't want to loose the tailgate. Looks like a solid deal though man. they are popping up everywhere now, so i may find what I want. Post pics if you get it man.
  5. Jan 3, 2010 at 3:50 PM
    cashman
    cashman [OP] Member
    western pa
    01 xtra cab
    ya i'm not certain about this style, but it just seems like too good of a deal, and its the same color as my truck
  6. Jan 3, 2010 at 11:33 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Is it a 95 pickup/Hilux or 95.5 Tacoma? Those are 2 totally different trucks.
  7. Jan 4, 2010 at 9:12 AM
    Afwrestler1986
    Johnstown, NY
    The CL add said Tacoma. IIRC
  8. Jan 4, 2010 at 10:14 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    OK, but does the seller knows what the seller is talking about? I find that most don't.
  9. Jan 4, 2010 at 10:37 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    cashman,
    do you know who mfg. the cap?? if so,go to their web site and check what vehicles that cap WILL fit....It would suck you purchase it and find out that 1/2"-1" difference makes it leak....
    S
  10. Jan 4, 2010 at 2:59 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Double-check to see if the cap was designed for a Regular Cab or an XtraCab. The rear cab walls have different profiles (slope), and some manufacturers slant their caps' front walls differently depending on which cab style the unit will be installed on.
    If it's a Regular Cab cap, there will likely be a noticeable gap between the front edge of the canopy and your rear cab wall.
    Just for the record ... That would be a mid-high canopy / cap (one whose roofline sits a bit higher than your cab). ARE never offered the rear hatch option on a cab-high model.
  11. Jan 4, 2010 at 3:20 PM
    Afwrestler1986
    Johnstown, NY
    This I can not confirm. although any Toyota truck is a Tacoma.......Right?!:rolleyes:
    (sarcasm was used in the making of this post)
  12. Jan 4, 2010 at 5:15 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    I wanted a cap for my '01 xtra cab. Wasn't wild about spending $1,000+ for the new cap.
    I noticed the dealer had a used cap that matched my black truck.
    We tried it by setting it in place "almost" perfect except the 3rd brake light at the top of the cab stuck out a bit and wouldn't allow the cap to come completely forward.
    The recess for the brake light was smaller than the brake light on the cab.
    The cap could come forward "possibly" if I removed the brake light and seal it from the weather.
    I bought it as is and have it on the truck for the last two years.
    A little overhang at the tailgate but liveable.
    $150.... installed.
