Question about Check engine light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazybrother, Oct 16, 2009.
  1. Oct 16, 2009 at 8:35 PM
    crazybrother
    crazybrother [OP] Member
    Hey guy's my check engine light came on the other day. I have a 2003 Tacoma xtra cab 4x4 (auto) with 93,000 miles. Is there any way to get the trouble codes without buying one of those expensive readers?? I took it to a shop that does alot of work on Toyota's and they can't seem to find the exact problem. They said is seems to be the "Heater Circuit" on one ot the O2 sensors. Any Ideas, and is there anyway to test them while on the truck?
    Thanks for any help?
    George
  2. Oct 16, 2009 at 8:39 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Scanguages arn't too bad better that than buy parts that dont fix the problem. Only $135.
  3. Oct 16, 2009 at 8:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Do you remember the exact code?
  4. Oct 16, 2009 at 8:45 PM
    crazybrother
    No, I forgot to ask. I'll ask him on Monday.
    Thanks.
  5. Oct 16, 2009 at 9:14 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    if it's a heater code for the 02 sensor it's generaly the sensor itself .it would be better to know what the exsact code is.if it is the heater code check your wiring and the female side of the terminals for proper tension.and on the scangauge reader i'm not sure if you can get to indepth with diagnosis like reading the sesor parameters.maybe someone that has one can chime in.i have only used make specific scan tools .best of luck keep updating there's alot of people that give good info on here.
  6. Oct 16, 2009 at 9:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    my cel went off for the first time the other day, so i got my buddy to scan it for me, and it pulled a"heater circuit/02 sensor code. i went and got one from the stealership, and replaced mine(upstream/bank1) and its been good since.
  7. Oct 25, 2009 at 4:02 PM
    crazybrother
    Alright guy's I finally got the code. P0031, anyone know what this one is & what do I need to replace?
    Thanks.
    The code came from the "Scangauge II"
  8. Oct 25, 2009 at 5:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i believe that the upstream o2 sensor code...same one i had.
  9. Oct 25, 2009 at 5:29 PM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    this is what i love about tw..... =D
