question about chips
Discussion in 'Performance and Tuning' started by 08 tacoma dirive, Oct 11, 2008.
  1. Oct 11, 2008 at 11:06 PM
    08 tacoma dirive
    08 tacoma dirive [OP] New Member
    Jackman
    red 08 tcaoma access cab
    what chip would be the best for my 08 tacoma v6 i was thinking of Unichip Performance Chip and if the money would be worth the preformance thanks for the help
  2. Oct 11, 2008 at 11:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think the only true module, as far as chips go, that will actually amount to anything is the urd maf calibrator. there really arent any "chips" for the newer tacomas. i cant really comment on the unichip, as i havent heard enough about it, but there is alot you can do with the maf calibrator. not saying the unichip doesnt work, just havent heard anything about it, and have heard lots of good about the urd product.
  3. Oct 13, 2008 at 8:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    With other mods you might unlock enough extra with a MAF Cal or the Unichip. But as a source of massive power gains...The chip alone just isn't it.
    You need to do some engine/systems work before you get outside the stock ECU's capability to compensate with the changes. (Like a complete air, fuel, or electrical system rebuild- forced induction for example) or new engine components- like cams valves, injectors)
    If you are planning on making a big prohect out fo it...Unichipo might be for you. My last truck had a SC and I used seperate piggy back fuel systems and a boost timing retard system. But it was a Dodge around 250cshp stock....and a 450rwhp when I got done.
    Figure out how much you want to put into the engine and go from there...
  4. Oct 17, 2008 at 7:16 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    When it comes to performance and the 4.0L 1gr, the unichip is low on the suggestion list.
    If you are wanting the most power out of the engine the APR X-1 controller is the best route. The next in recommendations would be the Map 2 ECU. Then for n/a vehicles just looking to make sure the air fuel ratio is solid, and picking up few extra hp the URD Maf Cal is a good product.
  5. Oct 17, 2008 at 7:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Would you happen to have a link for this.
  6. Oct 17, 2008 at 8:02 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
  7. Oct 17, 2008 at 8:16 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thanks man I couldn't find the APR X-1
  8. Oct 17, 2008 at 8:24 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    What ype of gains are you looking for?
  9. Oct 17, 2008 at 8:48 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I was just thinking that most vehicles meet the requirements of cali. and that I could use an adjustment in air/fuel mixture seeing as how I am living in Louisiana. I wouldn't mind finding something giving more low end torque but everything I see is for 3500 rpm and up, and I don't drive in that range much.
  10. Oct 17, 2008 at 10:53 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Ya that's a tough one to do... building low end torque. Forced Induction is a good way to build a bunch of low end.
