Question about Dakar springs
Discussion in 'Suspension' started by Iakopa84, Apr 5, 2012.
  1. Apr 5, 2012 at 5:13 PM
    Iakopa84
    Iakopa84 [OP] Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    Hey guys,
    I have some questions about getting/installing Dakar leaf springs I'm hoping you may be able to help me with! So, I have an '05 DCSB that I need to replace the factory leafs (they're basically an inverted U), and I've heard lots of good things about the Dakar springs - so those are what I want to install.
    First question - if I install them, are they going to raise my truck a bunch? I have a front leveling kit in (so as it sits right now, it's level) - will the springs make me sit front end low?
    Next question - if I replace the factory leafs, will I need to replace the rear shocks? Will the new leaf springs over-extend the shocks?
    Also, this is my shopping list for what I need. Do I have everything? Is there anything on the list I don't need?
    Dakar Leaf Springs
    U Bolts
    Axle Shims Do I need these?
    Driveshaft Bearing Drop Kit Do I need this?
    Thank you for your input and advice! :)
  2. Apr 5, 2012 at 6:00 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    yes it will lift, no axle shim, maybe on the cb drop and yes on shocks.
  3. Apr 5, 2012 at 6:03 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Centre pin collars in case you need to add axle shims
    I got 2 3/4" of lift over my saggy TSB 4 leaf pack
  4. Apr 5, 2012 at 7:33 PM
    Iakopa84
    Jake
    Escondido, CA
    Thanks all for replies and info!
    Guess I'll plan on getting new rear shocks as well
