Question about debadging and fading
Discussion in 'Detailing' started by SunDevilTacoma, Dec 15, 2009.
  1. Dec 15, 2009 at 6:28 PM
    SunDevilTacoma
    SunDevilTacoma [OP] Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    I'd like to remove the badges from the front doors but my concern is that I've had the truck 5 1/2 years and it is never garaged and since I live in sunny AZ should I be concerned about paint fading and/or lines? It's white so hopefully that will minimize the concern. What do you think?
  2. Dec 15, 2009 at 7:31 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    Taking off the badges should be fine. You'll probably find that the paint under the badges is perfect, but the paint on the rest of your vehicle has dulled a bit, or oxidised from sun and/or water and/or 5 1/2 years of wear and tear. I'd suggest having the exterior of your truck machine polished. Check out autopia.org. It's a detailing website with tons of DIY info. The folks over there range from people who detail their own cars for fun/hobby, to professional, career detailers. If polishing your own truck is not something you want to do, you'll be able to find a detailer from AZ over on autopia. Check the "click and brag" section of the forums for examples of their work.
  3. Dec 15, 2009 at 9:23 PM
    SunDevilTacoma
    Doug
    Gilbert, AZ
    Thanks, I'll check it out.
  4. Dec 16, 2009 at 6:32 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Agreed. That was the case with my truck, and polishing evened it out to where it was barely noticeable. The truck has been polished once or twice since then, and you cannot tell it ever had badges on it...
