Question about doing Calipers
Discussion in '1st Gen. Tacomas (1995-2004)' started by ikuczman, Aug 30, 2025.
  1. Aug 30, 2025 at 11:58 AM
    ikuczman
    ikuczman [OP] Member
    I have an 2003 Tacoma with original Calipers & Caliper Brackets.
    Do I need to Replace the caliper brackets? Or can I run them again as long as the mating surfaces are good and the boots are still somewhat intact?
    Thanks for the input.
  2. Aug 30, 2025 at 12:09 PM
    Darce
    Darce Well-Known Member
    2003 Tacoma
    You can reuse the brackets.
    ControlCar likes this.
  3. Aug 30, 2025 at 4:38 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    NEVER have I to RR a caliper bracket
  4. Aug 30, 2025 at 4:41 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Reuse the brackets no need to replace.
  5. Aug 30, 2025 at 10:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't you have a 6-lug? The caliper is a fixed/non-floating design. Curious what you're calling a bracket..
    Usually the term "bracket" refers to the half of a floating caliper that bolts directly to the knuckle and holds the pads. The other half "floats" on greased slide pins and holds the piston and brake line
