question about drying and using a hydrate
Discussion in 'Detailing' started by Do58, May 5, 2017.
  1. May 5, 2017 at 2:43 PM
    Do58
    Do58 [OP] Well-Known Member
    2015 white tacoma limited
    new to the whole detailing thing and I know that there are so many different products out there. one thing that I see is when people are drying they are using AMMO hydrate. I didn't see it on Amazon or if there was a different brand that people use and have had success with that you can get from a local retail store. looking to get it asap and try it out. also, thinking about getting a foam cannon ( I do have a power washer ) but is there something as good that you can use off the water hose? never have used a cannon or attachment so is there a special pressure solution that I have to use or just use the soap I am using to wash? recommendations?? thanks for any help
  2. May 5, 2017 at 4:04 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I doubt there is anything you can get at a retail store unless you have a detailing store near you.
    Nothing that hooks up to a hose will work like a foam cannon. Foam guns are probably the closest thing but they do not lay down foam like a cannon.
    As far as mixture, I just use my Adam's car shampoo. You will need a quality soap. Usually a concentrated soap works better.
  3. May 5, 2017 at 8:17 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    You can use most any detail spray or spray wax as a drying aid. They just add some lubricity to the surface to help prevent towel induced swirls when drying the vehicle. Some spray waxes might streak and require a flip or two of the towel to a dry side for a final wipe.
    I often use Duragloss Aquawax as a drying aid. Megs Ultimate Quick Wax isn't bad either if you want over the counter stuff. If you have a detail spray, that's fine too. Griots Speed Shine is nice. Try something out, if you don't like it, try something else.
    CusterFan likes this.
  4. May 5, 2017 at 9:00 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use a Leaf Blower to blow most of the water off and then follow up with a Microfiber Drying Towel, the Leaf Blower also does a great job at getting water out of the stubborn areas.
    20tacoma17 likes this.
  5. May 5, 2017 at 9:05 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I've been doing the same for years with a cheap electric blower. Wonder if the ones made specifically for blowing off cars are any good but can't see spending $2-300 for one.
    shakerhood[QUOTED] likes this.
  6. May 5, 2017 at 9:07 PM
    shakerhood
    Southern Ohio
    Same here, a $30 or $40 Electric Blower does the job. I could not see spending that kind of cash for a specific one cause I could not justify the cost.
    20tacoma17[QUOTED] likes this.
  7. May 7, 2017 at 7:44 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Duragloss Aquawax.
