Question about engaging 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nextlevel, Jan 28, 2010.
  1. Jan 28, 2010 at 11:38 AM
    nextlevel
    nextlevel [OP] Member
    NJ
    Speedway Blue TRD Offroad
    We received a light snow in NJ today to make the roads slippery. I was going around a turn on this morning and started slipping. Let go of the gas, slowed down, then engaged the 4wd with the wheels turned slightly and heard a noise. Do you think it cause damage to the 4wd since I engage it with the wheels slightly turned? I'm new to the 4wd drive but i know you want to make sure the wheels are straight. Just want to make sure i didn't cause any damage.
    Thanks for the help.
  2. Jan 28, 2010 at 11:40 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    If the roads were slippery I doubt you caused any damage at all, but it is better to engage and dis-engage the 4x4 while going straight. I've used my 4x4 in the snow quite a bit lately and sometimes it makes some noise, but I have had no problems with my system at all. BTW, welcome to TW.
  3. Jan 28, 2010 at 11:40 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    No damage. When you shift into 4 wheel drive you are engaging the transfer case to drive the front differential. Whether the wheels are turned on the front differential should make no difference
  4. Jan 28, 2010 at 11:43 AM
    nextlevel
    NJ
  5. Jan 28, 2010 at 11:44 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    sometimes they make a clunk sound when engaging.
