Question about Fox 2.5 Coilover with Resi
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheSharksDen, Jul 28, 2019.
  1. Jul 31, 2019 at 12:51 PM
    #41
    TheSharksDen
    TheSharksDen [OP] Well-Known Member
    19 Taco OR DCSB 4x4 (Cement)
    They charged me two hours of shop time for it...
  2. Jul 31, 2019 at 2:03 PM
    #42
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    They do 4"+ lifts all day long...scary, huh?
  3. Jul 31, 2019 at 2:57 PM
    #43
    Flatliner
    Flatliner Well-Known Member
    Robert
    2008 Tacoma Double Cab TRD Sport
    Fox and Icon Suspension upgrade
    I shouldn't publically admit this but I installed BOTH my front shocks like this by mistake because I was in a hurry trying to get the job done before a family event. had to drop them back out the next day to fix it... (lock ring in the back, not the other crap in the thread...)
  4. Jul 31, 2019 at 3:20 PM
    #44
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    The guys that say you don't, only drive on road
  5. Jul 31, 2019 at 3:34 PM
    #45
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    This is a CMC: https://www.tacomaworld.com/threads/3rd-gen-cmc-quick-diy.618098/
    Your truck clearly doesn't have a CMC. If that's a line item, I'd be upset and potentially dispute the charge if they're unwilling to be honest with you.
    Furthermore, there is absolutely no excuse for installing a Fox shock with the adjusting collar on the wrong side. That's simply a lazy installation, and they need to fix that free of cost.
    I have the same shocks (2.5 body) without the reservoir, and 285/75s (33" tires). My adjusting collar is the same design as you described, that's completely normal.
    If you're rubbing on the shock, then you have too much backspacing or offset on the rim. You can correct that with a wheel spacer. I run these: https://www.amazon.com/gp/product/B07D755775 with the extended lug nuts and don't rub on stock SR5 rims. The SR5 rims and SR rims have more offset (or backspacing, can't remember which), so they will need a spacer to clear 33s. Stock OR and PROs rims don't need the spacer to clear 33s. Sounds like the rims you chose need a spacer, which is your fault / problem if you chose the size and backspacing, but their problem if they did. People will trash-talk spacers all the time, but they're fine - don't stress, just install to the torque specs with loc-tite and you'll be golden.
    Hope that helps. :thumbsup:
  6. Jul 31, 2019 at 3:38 PM
    #46
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Not necessarily true if you’re not supposed to be making adjustments with tension on the shock. You can get all hot and heavy but it’s not lazy if it’s by design not supposed to happen.
    See bold.
  7. Jul 31, 2019 at 4:20 PM
    #47
    synaps3
    Dave
    Los Alamos, NM
    No. You can adjust Fox shocks with tension on them. The installation manual says:
    Source: http://pvg-portal.ridefox.com/_context/fox/__uploads/_assets/605-01-107_REV_C.pdf
    The installation manual says you can adjust preload after installation. >
    They installed it in a way that doesn't allow preload adjustment after installation. >
    Therefore it was installed wrong.
    It is difficult to adjust preload when they're installed, but it's not impossible. I have adjusted mine multiple times. It's way easier to adjust them on a spring compressor off the truck, but there's no problem at all adjusting them on the truck. I jack the front of the truck into the air so the wheels are off the ground, put jackstands, remove the wheel, use a shitload of pb blaster as lube on the threads, and loosen the collar. I stick a punch instead of a spanner tool in the hole and yank it like a teenager discovering his dick. The collar spins, the preload increases or decreases, rinse repeat until your preload is where you want it.
    If they adjusted them before installing them on the truck or (more likely) just put them on without adjusting them, there is no excuse but laziness or inattention to detail. Why would you ever want to be entirely unable to access the ADJUSTING portion of your adjustable preload shocks?
    TheSharksDen[OP] likes this.
  8. Jul 31, 2019 at 4:40 PM
    #48
    Joe23
    Depends on how much preload and what spring.
    I know when I had my coils swapped to 700lbs they had to use a spring compressor just to get them down to adjust.
    Shop that did them said last time he tried adjusting a 700lbs spring on the fox 2.5 the spring started to dig into the adjustment collar.
  9. Jul 31, 2019 at 4:44 PM
    #49
    synaps3
    Dave
    Los Alamos, NM
    I have 700lb springs too... I have a winch bumper. :rofl:
    Mine are Eibach 1400.300.0700s, so same spring as the factory, just higher rate. They were a BITCH to install, but not too bad to adjust.
    Maybe 2nd gens are different? I just don't want OP getting the wrong idea - shocks with adjustable preload should be installed so you can adjust the preload.
  10. Jul 31, 2019 at 4:47 PM
    #50
    Joe23
    completely agree.
    same thing for me haha had to upgrade to 700lbs with the ARB bumper. Not sure if 2nd gen is different. Doubt it though.
    If anything I would just say its something to be aware of and to watch for when adjusting under preload.
    synaps3[QUOTED] likes this.
  11. Jun 4, 2021 at 2:04 PM
    #51
    Raul4431
    Raul4431 Active Member
    Raul
    Concord, NC
    2021 Black Tacoma TRD PRO
    Question where can I buy the screws that bolt on top of this exact shock? Thanks all
  12. Jun 9, 2021 at 9:47 AM
    #52
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    I would call the manufacturer and see if they will sell/send you them
  13. Jun 9, 2021 at 10:08 AM
    #53
    Raul4431
    Raul
    Concord, NC
    Sounds good I'll give them a call.
  14. Jun 9, 2021 at 10:13 AM
    #54
    desertjunkie760
    Shane
    Check My Sig.
    Don't waste your time. You can get them from any hardware store.
    3/8"-16 x .0875 TLG; Grade 8 and the accompanying washer.
