Question about Fox rear shocks
Discussion in 'Suspension' started by SlapChop7, Sep 5, 2015.
  1. Sep 5, 2015 at 2:05 PM
    SlapChop7
    SlapChop7 [OP] Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    I've searched around looking for an answer and even PMd a couple people but its a holiday weekend and I'm sure people have better things to do than answer PMs. Anyways, I ordered these Fox rear shocks last night from Wheelers: PN: 985-24-117 for 2"-3" of rear lift.
    Now I have Wheelers 3 leaf Progressive AAL that I'm going to install with the overload for a little over 2" of lift. My question is do I need to also buy Wheelers bump stops? If so, could someone school me up as to why or provide a link somewhere that does? Thanks guys.
  2. Sep 5, 2015 at 2:15 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    the stock bump stops will work. The Wheelers bump stops are less jarring when you bottom out the axle against the frame.
  3. Sep 5, 2015 at 2:31 PM
    SlapChop7
    Eastern NC
    Ok. I just want to make sure I don't damage the shocks.
  4. Sep 5, 2015 at 2:36 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Not necessarily, assuming you'll be installing these in the stock location?
    For every 1" of added shock travel, you're going to loose appox 1/2" of bump travel. If the shock is able to accommodate 3" of lift, you are going to want to double check your bump clearances.
    My suggestion would be to cycle your rear suspension with just the main leaf, since you'll have to separate the pack for the add-a-leaf anyways, and see for yourself if you need taller bump stops. If you do, you can easily order them, and just be sure not to bottom out your suspension until they arrive.
  5. Sep 5, 2015 at 5:07 PM
    SlapChop7
    Eastern NC
    Awesome thank you
  6. Sep 5, 2015 at 7:37 PM
    SlapChop7
    Eastern NC
    What about extended brake lines for the rear? Are they required?
  7. Sep 5, 2015 at 7:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not necessarily required. I got 10" Fox shocks and all I did was create a small spacer between the axle and the brake line retention bracket. Worked well for me and I haven't had any issues.
  8. Sep 5, 2015 at 8:56 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    If it's in your budget, you may as well. Like I said though, make sure to droop everything out and make sure nothing is asp ting like a limiting strap.
