question about fuel pump
Discussion in 'Technical Chat' started by Silvert, Jun 27, 2011.
  1. Jun 27, 2011 at 8:36 PM
    Silvert
    Silvert [OP] Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    I have a 2010 Tacoma reg. cab, 4 cylinder, 5 speed. Today, a good hour after I parked it in the garage I could hear a humming noise from the left rear. It sounded like the fuel pump was running. I turned the key on and off again and it stopped. Any ideas out there? Thanks, Jeff
  2. Jun 27, 2011 at 8:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    next time you hear it,loosen the gas cap and see if it goes away.it maybe venting the pressure from the fuel tank.
  3. Jun 28, 2011 at 5:39 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I've had this happen to me on my 2011. Similar senario, parked in the garage on a warm day. I'm pretty sure it was the fuel pump venting the tank. I loosened the gas cap and a rush of air came out. The pump stopped immediately. I've wanted to look it up on a schematic to verify, just haven't taken the time.
  4. Jun 28, 2011 at 5:47 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That is the EVAP system working, not the fuel pump. It tests the vaccuum of the fuel system, checking for leaks.
  5. Jun 29, 2011 at 8:26 PM
    Silvert
    Jeff
    Wisconsin
    Thanks for the great tips!
    Silvert
