Question about gear oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bwanamukubwa, Jul 2, 2013.
  1. Jul 2, 2013 at 10:05 AM
    bwanamukubwa
    bwanamukubwa [OP] Well-Known Member
    Tennessee
    I'm coming up on 30,000 miles and plan on driving my truck into the ground. Has anyone got experience and can confirm the quantities using 75w-140 (GL-5) for the following:
    - Manual transmission: 1.9 qt
    - Transfer case: 1.1 qt
    - Front diff: 1.6 qt
    - Rear diff: 3.0 qt
    Total = 7.6 qt (or about 1.9 gallons)
    I was just going to buy 2 gallons of Redline 75w-140 (to account for whatever i might spill) with some Amazon points i have left over. Is there anything i should be weary of?
    Just wanting to learn as much as possible from the more knowledgeable folks on here. thanks in advance!
    Here is the Redline: http://www.amazon.com/Red-Line-5791...F8&qid=1372784201&sr=1-1&keywords=redline+140
  2. Jul 2, 2013 at 10:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I can confirm all by the manual transmission. All the quantities were pretty close to what was specified. My manual said to use 80W-90 for the rear and 75W-90 for the front diff and x-fer case though. 140 weight is thick stuff, why are you going so heavy?
    I'm sure you know this, but get the fill plugs out before you pull the drain plugs!
  3. Jul 2, 2013 at 10:31 AM
    bwanamukubwa
    Tennessee
    You're saying the 75w-140 is ok for the manual transmission? The way i understood it, 140 is better for a larger range of temperatures. If i understood wrong, i apologize and i'll stick to 75w-90, or do you think it's important to go with the 80w-90 for the rear?
  4. Jul 2, 2013 at 10:33 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I went 80w90 for the rear
  5. Jul 2, 2013 at 10:40 AM
    bwanamukubwa
    Tennessee
    Your truck is sick man!
  6. Jul 2, 2013 at 10:45 AM
    Pugga
    Massachusetts
    No, I'm not saying anything about the manual transmission, I have an auto.
    I was saying that the specified quantities for the x-fer case, front and rear diffs are pretty close (the quantities you listed are very close to what they actually take).
    XW-140 is a heavy oil and can make your MPG's suffer. Unless you really plan on abusing your differentials, it's too heavy for normal use in my opinion and you do not need anything that heavy. I stuck with 80W-90 for the rear and 75W-90 for the front and transfer case and it's been doing great. I'm pushing 90k miles and have towed and hauled pretty heavily with mine.
  7. Jul 2, 2013 at 10:46 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +2, or 75W90, it takes a little over 3 qts.
  8. Jul 2, 2013 at 10:47 AM
    bwanamukubwa
    Tennessee
  9. Jul 2, 2013 at 11:06 AM
    anthony250f
    Anthony
    San Diego, CA
    Thanks man ! Mine took exactly 3qts
  10. Jul 15, 2013 at 4:38 AM
    bwanamukubwa
    Tennessee
    Hey guys, so i finally finished up changing out all the oils. Rear and front diff were kinda dark but not too bad. Transmission and transfer case were pretty clean so i am happy.
    However, i ran short of some Redline 75w90 GL-5 so if anyone has some left over in a bottle they didn't want to throw away and won't be using, please let me know and i'll pay for shipping.. just didn't want to spend another 20 bucks on a quart.
  11. Jul 15, 2013 at 7:39 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    $20/quart? wow, that is pricy stuff...The top shelf Valvoline, Mobil, Citgo or other major brand of gear lube is normally about $75 for a five gallon pail or under $20 a GALLON. I would have to see some good data on why a such a super premium oil benefits such a light duty vehicle...Most folks I know who operate equipment in heavy duty applications, Iron Butt motorcycles, OTR Class 8 trucks, logging and construction equipment just stick with a major brand when available, and in a pinch, the FLAP house brand with the right GL5 certs.
    Why don't you see what Bob the Oil guy has to say?
    Howard
  12. Jul 15, 2013 at 7:58 AM
    bwanamukubwa
    Tennessee
    Lots of folks on here recommend the Redline full synthetic. Either way i spent ~120 on oil because i'm saving a couple hundred dollars doing this myself instead of taking it to the dealer and wanted peace of mind. Truck drives like a dream now btw.. I know i got good oil so i'm not going to start over.. i literally need less than half a quart to finish.
  13. Jul 15, 2013 at 2:37 PM
    hetkind
    Howard
    Johnson City
    Best of luck...I have a '11 Taco manual I am using Valvoline in, why don't we compare notes in 300k on oil cost and gear box/pumpkin rebuilds?
    Howard
  14. Jul 16, 2013 at 6:47 AM
    bwanamukubwa
    Tennessee
    Haha, if i had my Hilux i would definitely take you up on that..
  15. Jul 16, 2013 at 7:39 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
  16. Jul 16, 2013 at 8:16 AM
    bwanamukubwa
    Tennessee
