Question about getting new leaf springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by strongwxnc, May 23, 2010.
  1. May 23, 2010 at 8:02 PM
    strongwxnc
    strongwxnc [OP] Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    I plan told replace both front and rear shocks in the next year. I would like to level or add a little lift. Thinking 5100 due to price .. The truck is at stock height.
    But my question is, Do I need to replace my leaf springs? Both packs are laying close to flat. I have read around here for the past few weeks but I still have not found a good answer. Prices are high for the leaf packs and I really want to make sure I need them. I do not tow much or at all. The most weight I have in the bed is if it is full of mulch or building materials.
    Also, I have read about axle warp. What is the best way to check my truck. It is a 5spd.
    Just trying to firgure out where I can get the most bang for my $$..
    Thanks!!
  2. May 23, 2010 at 8:03 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    damn. you just missed a group buy on wheelers leaf packs.
  3. May 23, 2010 at 8:41 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Most Tacoma leafs are pretty flat from factory. Mine are about flat, but still in good shape. If your rear is still higher then your front, then I think your's are ok. Its when you start noticing the rear getting level with the front and there Frowning. Then there bad...
  4. May 24, 2010 at 4:26 AM
    strongwxnc
    Bostic, NC
    Yeah I saw that :(
    Yep. My rear is still higher than the front. I did not know if that meant my springs were ok or not. I guess what Im feeling (like the truck bottoms out when I cross RR tracks or dips) is the need for new shocks front and back.
    Thanks fellows...
  5. May 24, 2010 at 5:06 AM
    jjadkisson
    jjadkisson Active Member
    Josh
    Zuni, Va.
    2000 Taco SR5 Pre-Runner
    A.F.E. Magna Flow Intake, Tranny Cooler, AAL, Reese Trailer Brake Controler
    Same with my rear leafs on my 00'. They have not ever had a signifigant "Bow". This weekend I installed a "helper leaf" kit made by Hellwig.
    The leaf is about 18 in. long and shackes over the top of your existing pack behind the axle. It's made for keeping your ride height natural (no sag) when towing or having the bed loaded.
    I just ordered a Hi-rise topper for my truck and I did'nt want the rear end to sag with the added weight of the topper plus whatever I throw in the back.
    Also, I've notice a better ride on the highway when it comes to bumps and railroad tracks....the rear end no longer "dances" when you hit bumps etc. at speed....I put new shocks (Monroe) on about 8 months ago and that helped greatly but the helper leaf made it that much more plush.
    I bought the kit through Advance Auto for around $60.00, took about 1 1/2 hours to install including jacking and clean-up.
  6. May 24, 2010 at 5:15 AM
    strongwxnc
    Bostic, NC
    Nice.
    Yep. The back end loves to dance around with me. Also, if my bed is loaded down it sags a good bit. I will check into the link man.
    Thanks
    Edit. I was unable to find it at advance online.
  7. May 24, 2010 at 6:56 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    if your stock leafs are still in pretty good shape, i highly recommend the deaver 3 leaff add-a-leaf pack.
    it actually rode and handled weight better than my current alcans. ...and they're also inexpensive compared to new leaf packs.
  8. May 24, 2010 at 7:43 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    I added the toytec 2" AAL and that thing has some serious arc to it.
    Cheap and added 2" height.
  9. May 24, 2010 at 7:48 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I just installed new leaf springs a 5 pack from Wheelers, and after installation the pack is pretty close to being flat. It does have a slight smile but its nearly flat. So I guess, its normal to have a flat pack, but frowning is bad. It did lift the rear a 1.5" as advertised and the Billies are smooth as butter!
  10. May 24, 2010 at 7:55 AM
    strongwxnc
    Bostic, NC
    Cool.
    I guess I was just worried about "not" doing anything to the leaf springs, if they needed it. From some of the posts here and other thread I have searched, mine look close to normal. Make snap a photo later and post for thoughts.
    Might lean towards the Leaf Spring Helpers (as I like the height of the rear) and do 5100 (to level the front) all around.
    The spring helpers hopefully will assist my truck to staying level when it is loaded down. Fill like $hit when I haul Mulch...
    If you are like me, it is hard to spend money and you want to make sure you get what you need.
  11. May 24, 2010 at 11:46 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you don't want to lift the rear and like the ride. You may want to look into a set of TIMBRENs for the rear. They will keep the suspension charateristics the same, but when loaded the timbrens will come into play an keep the rear from sagging too far.
  12. May 24, 2010 at 12:00 PM
    strongwxnc
    Bostic, NC
    Nice. Never hear of them before. Yea, I like the stock height in the rear. But the truck does go down when im hauling. Wish they were cheaper :)
    Thanks
  13. May 25, 2010 at 6:12 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Yea the TIMBRENS or the Air Springs systems would be nice. The TIMBRENS are slightly cheaper.
  14. May 25, 2010 at 9:55 AM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    I'm doing basically the same thing that you are planning on doing. Gonna get the 3" lift leafs from All-Pro and set the billies at 2.5" up front. My suspensions needs a complete overhaul... All-Pro's price seems to be pretty good, and I have heard good things.
  15. May 25, 2010 at 8:13 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    For about $1000 you could go with an Old Man Emu Suspension.
    I just got one and I am installing it soon... It is a mild lift - about 2 inches.
    It should last twice as long as the factory suspension.
    Just fix it right the first time and you wont have to mess with it later.
    The rear springs are much beefier. They are designed for added weight and off road.
    All pro, Deaver, Alcan, etc are usually designed for flex and not load bearing.
  16. May 26, 2010 at 4:25 AM
    strongwxnc
    Bostic, NC
    So many different ways to go on this one..... Either way, looks like I need to start saving my money. I would like to do it right the first time.
    Thanks Man!!
  17. May 26, 2010 at 9:15 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Depending on the miles or year and since you are doing a overhaul on the suspension, why not replace the leafs as well? I would.
  18. May 26, 2010 at 9:23 AM
    strongwxnc
    Bostic, NC
    Starting to think I need to replace everything.. :)
    The springs have 163,000+ on them....
  19. May 26, 2010 at 9:31 AM
    strongwxnc
    Bostic, NC
    You got a link to where you bought OME suspension ?
    Thanks..
  20. May 26, 2010 at 4:06 PM
    scocar
    scocar Patron of the Farts
    Toytec sells them too, don't have the link. Lots of places sell them. Just google OME coil to see where you can get the best deal. Some vendors on this site offer discount to memebers, too.
