Question about headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sguntharp, Apr 28, 2020.
  1. Apr 28, 2020 at 5:42 PM
    sguntharp
    sguntharp [OP] New Member
    Seth
    2012 Toyota Tacoma
    Hey guys. I am brand new to this forum but I wanted to ask a question. My wife's father just gave us his 2012 Toyota Tacoma. It has its original 9003 H4 headlight bulbs that are not very bright. I am wanting to upgrade to LED headlights. What would be your recommendations for LED bulbs? I am trying to keep the price under $100.
  2. Apr 28, 2020 at 5:59 PM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    I have tried 2 different brands of LED bulbs in the stock headlight housing. Both were highly rated and highly recommended over competitors from the research I did. Both produced disappointing results in the stock headlight housing. I wish I had my money back.
    VanDoom likes this.
  3. Apr 28, 2020 at 6:11 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  4. Apr 28, 2020 at 6:17 PM
    tacomadude18
    tacomadude18 18 Tacoma Cement
    Carlos
    Midland TX
    TRD Off Road DCLB
    K&N cold air intake
    Look into aux bean I like those a lot. Paid 75$ I think. Check Amazon.
  5. Apr 28, 2020 at 7:04 PM
    Osscar6090
    Osscar6090 Member
    2015 MGM DCSB TRD-OR
    I had some HID’s on my 2015. Light output was nice but had some condensation issues, and didn’t like having all the extra wires under the hood. So I switched back to Halogens and have never been happier.
  6. Apr 29, 2020 at 11:59 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Are the lenses cloudy then clean/sand/polish them first many posts on DIY.
    Buy a set of new bulbs with a whiter light up at 6000 range and all auto stores have 3 levels of white.
    Stay away from the super white/blue range ones as they piss us all off.
    Make sure they are aimed correctly again DIY posts on that.
    Island Cruiser likes this.
  7. Apr 29, 2020 at 12:31 PM
    Hobotang
    Hobotang Member
    Knoxville
    2013 Tacoma Reg Cab 5 Speed
    vssman[QUOTED] likes this.
  8. Apr 29, 2020 at 12:35 PM
    Jllahman
    Jllahman Well-Known Member
    Jordan
    Northern Kentucky
    2008 Rugged Trail
    I would look into HID bulbs. I don't have experience with them in the stock Tacoma housings, but had great results in other H4 OEM housing vehicles. Or for cheap, just get a quality bulb for under $25.
    I went with these:
    https://www.amazon.com/gp/product/B0085NS3XU/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    Very bright and crisp white, no blue coloring to them. Also did the black headlight mod, and do what muddog321 above said, sand, polish, and clear the lenses.
  9. Apr 29, 2020 at 12:39 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    DO NOT put LED or HIDs into the stock housing. This housing uses reflective materials to aim the halogen light. LEDs and HIDs use much different technology and aren’t meant to be used with the reflective style housings. If all you want is a good bulb there are plenty of good halogen options you can find with 1 google search. If you really want to go LED or HID then there’s a bunch of threads in here that you can read research and find out exactly what you want
    vssman, Island Cruiser and gasgasman like this.
