Question about installing hi/lo hid kit (1st gen)
Discussion in 'Lighting' started by emglishe30, Jun 9, 2010.
  1. Jun 9, 2010 at 8:24 AM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    01 2WD Taco 2.4
    Debadged to TACO, Kenwood reciever, pioneer 6 X 8's, sunpro 3" tach, assorted led lights, sirrius, gps...
    Ok I just got my slim ballast ddm kit and was looking for a guide to install the kit for the 1st gen tacoma. I can figure the directions out even though they seem shitty. I don't want to mess anything up so a little direction would be great.
  2. Jun 9, 2010 at 11:58 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Uhhh it's pretty straight forward. Take out stock bulb, put in the new ones. all of the connections go into each other, can't really plug in something wrong. Plug in the relay harness into the factory headlight bulb harness. Hook up the ground wire to the body or negative terminal of battery. Once all done, hook up positive wire to positive terminal of battery.
  3. Jun 9, 2010 at 3:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Yeah, its' pretty straightforward. Like Viet said, you can't plug in something wrong, it's pretty obvious how it should be connected.
  4. Jun 9, 2010 at 6:01 PM
    emglishe30
    NJ
    01 2WD Taco 2.4
    I was looking more for ideas where people placed there ballasts and what not...
  5. Jun 9, 2010 at 6:07 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    i velcro'd and ziptied my ballast on the side of the frame
  6. Jun 9, 2010 at 8:24 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Then why didn't you specifically ask that in your original post? :confused:
  7. Jun 9, 2010 at 11:06 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Where ever they will stay as dry as they can be, away from heat, and not flopping around.
