question about keyless entry
Discussion in '1st Gen. Tacomas (1995-2004)' started by vballrkc, Jul 1, 2013.
  1. Jul 1, 2013 at 9:36 AM
    vballrkc
    vballrkc [OP] Active Member
    Houston area
    01 double cab 4 cyl SR5
    Ok, I bought my 2001 tacoma back in march i think, and the keys the dealership gave me had an aftermarket key fob on it that I assumed was for the alarm and keyless entry. Well, come to find out, it had an aftermarket alarm system on it and the dealership doesn't sell vehicles like that, so they took it out. now i have no keyless entry. My question is does the truck still have the original keyless entry in it, and all I have to do is get a stock key fob? I am sure that that would be to easy and I will have to buy an aftermarket keyless entry system, but I was wondering if htere was an easy way to tell if the truck still has the oem keyless entry on it? Thanks guys.
  2. Jul 1, 2013 at 11:42 AM
    nigglewiggle60
    nigglewiggle60 Well-Known Member
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    Rubber mats, Bluetooth.
    Call a toyota dealership and give them your vin #. They should be able to tell you if it came with keyless entry or not. You would be surprised that most didn't come with keyless entry.
    If you want to you can look for the parts to convert, but good luck with that. Easiest thing to do is just go with an aftermarket unit.
  3. Jul 1, 2013 at 5:39 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    Amazon, buy you an Avital 2101L its just a basic keyless entry and fairly simple to install, i did mine, it worked fine, then i decided to up it and put an encore E4 alarm and remote start on it, i do work in a car electronics shop, but its not complicated AT al, hope this helps you out
  4. Jul 2, 2013 at 6:12 AM
    vballrkc
    Houston area
    Ok that's what I was afraid of. thanks for your help.
