Question about leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tdeguzman, Sep 13, 2009.
  1. Sep 13, 2009 at 6:46 AM
    tdeguzman
    tdeguzman [OP] Member
    SOMD
    2014 Tundra CM 4X4 MGM crew
    i am looking into a 3" spacer leveling kit... will the 3" kit make the front sit higher than the rear? and i don't want to just buy the 2.5 and still have a front lean.
    in due time i am getting 5100's all around but for now im just putting the spacers on, i have heard pretty good things but also heard bad things. the good things out weight the bad so i decided to go this route.
  2. Sep 13, 2009 at 6:55 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    u'd be better off buying the front 5100's now and ditching the spacer lift idea...then getting the rear 5100's when u can. a 3" spacer would have it sitting nose high if you do nothing to the rear. most "leveling kits" are around 2.5" b/c a leveling kit does nothing to lift the back. a 3" spacer "lift kit" shold have something to lift the rear and will pick it up to be level with the front end. for the price of a 3" spacer "lift kit" u can get the front billies that u are looking to get anyways. talk to downsouth on here for the hookup on the 5100's
  3. Sep 13, 2009 at 6:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Ditto ^^^^^^^^^^^^
  4. Sep 13, 2009 at 6:59 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
