question about lift?
Discussion in 'FJ Cruisers' started by csmobley, Mar 18, 2013.
  1. Mar 18, 2013 at 6:41 PM
    csmobley
    csmobley [OP] Well-Known Member
    Shanon
    Colorado Springs, Co
    2018 Toyota 4Runner TRD Off Road
    Gobi stealth rack 17x8.5 SCS F5, 285/70R17 BFGoodrich All Terrain KO2, Toytec suspension, Shrockwork sliders, Xenon Depot HID conversion, led fog light kit, TRD Pro conversion front end, front and rear valence
    I am thinking of doing a 3" lift, and was wondering if anyone knows if this will accommodate a 285/70r17 without having to make any modifications or cutting anything?
    Thanks
  2. Mar 18, 2013 at 6:43 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Good chance it will rub to some degree if you literally want to do zero trimming at all.
  3. Mar 23, 2013 at 12:44 PM
    jluu44
    jluu44 Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    It will depend on your tire/wheel set up. If they are aggressive 33's, then they will most likely rub with the body mount. You will need to do a body mount chop for some more clearance. I've seen ppl run a 3" lift with 33's and they didn't need a chop.
  4. May 20, 2013 at 8:43 PM
    runner05
    runner05 Well-Known Member
    Karl
    33's on 3" lift might rub slightly, but that will be fixed with some trimming. You can put 32s if you don't want to cut anything. I know some people who have this kind of setup.
  5. May 23, 2013 at 4:10 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    to give you some kind of comparison I have a 3 inch lift and running Nitto Trail Grapplers (285/75/16) no BMC, factory wheels, 1.25 spacers. I get a slight rub if I'm at a full turn and hitting a curb, but everything is normal other than that. I bet a 17 would rub more, but let's see if anyone else has real experience with that. On a side note, the stores (ACE/Lowes) are having a good sale on angle grinders. I'm thinking about stopping by ACE for a DeWalt Angle grinder for $40 this weekend to do my BMC.
