question about lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rogue_12, Feb 4, 2025.
  1. Feb 4, 2025 at 1:11 PM
    Rogue_12
    Rogue_12 [OP] Active Member
    Hello all,
    I was looking to upgrade the suspension on my SR5. I plan on doing Bilstein 5100s all around and an Add a Leaf in the rear. I read somewhere on here that if you have an SR5 you should also upgrade the coilovers and springs when going with a setup like this on SR5s. Is this a true statement? Any advice is appreciated. (I plan on upgrading to 275/70/17 tires as well)
    Tocamo likes this.
  2. Feb 4, 2025 at 1:41 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    There is nothing about your SR5 that requires special treatment. The Pro is the only trim with a significantly different set of shock absorbers.
    Chew likes this.
  3. Feb 4, 2025 at 2:08 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the or ?
    BillF1564 likes this.
  4. Feb 4, 2025 at 2:10 PM
    gudujarlson
    Minnesota
    I have owned both an sr5 and an or. I noticed nothing different about the shocks on or off the road.
  5. Feb 4, 2025 at 2:12 PM
    RIX TUX
    i thought the sr5 had a harder street ride
  6. Feb 4, 2025 at 2:15 PM
    gudujarlson
    Minnesota
    People have certainly said that. How many of them have owned both?
  7. Feb 4, 2025 at 2:22 PM
    RIX TUX
    no scoops here but the sr5 has hitachi shocks so must be different
  8. Feb 4, 2025 at 2:37 PM
    gudujarlson
    Minnesota
    I’m aware they are different, but I did not notice any difference. It’s possible the OR shocks have more ability to shed heat and I never really pushed either to their heat dissipation limit.
  9. Feb 4, 2025 at 2:41 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Hitachi's vs Bilstein. How did you not notice?
    3GTCMLMTD and eurowner like this.
  10. Feb 4, 2025 at 2:41 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I have 5100s all around and I changed no coilovers or springs. I did leave my truck at stock height.
    Tocamo and Rogue_12[OP] like this.
  11. Feb 4, 2025 at 7:24 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    I regret not trying my stock springs on the Bilstein 5100s first before buying new springs for them.
    Tocamo likes this.
  12. Feb 6, 2025 at 2:22 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    It was a no brainer for me. Bilstein recommended it, I listened...
    Canadian Caber and Burns like this.
  13. Feb 6, 2025 at 5:35 PM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    Did you get a length and spring rate from Bilstein by chance?
    Not having mine anymore for comparison is my regret.
  14. Feb 6, 2025 at 6:45 PM
    gudujarlson
    Minnesota
    I’m not sure if you are serious or making a joke.
  15. Feb 6, 2025 at 10:29 PM
    JoshC
    JoshC Well-Known Member
    2023 TRD Off-Road M/T Celestial Silver
    1999 SC 2.4L 2WD 5m/t (RIP)
    Sell your measly little 1/4 ton and replace it with an F-250 or a Ram. If you want to lift it you obviously want a bigger truck so why'd you but a tiny little Taco in the first place?
    RIX TUX and BillF1564 like this.
  16. Feb 7, 2025 at 9:56 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sorry Mike, no
  17. Feb 7, 2025 at 2:09 PM
    Rogue_12
    :duh:
    BabyBilly likes this.
  18. Feb 9, 2025 at 6:05 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    :D. I know your kidding buddy, when you said this.
    Love my little lifted 1/4 ton truck Josh and would NEVER, EVER get stuck with an F-250 or a Ram. My Taco does what it needs to, looks awesome doing it, and is SUPER reliable.
    Can't say the same for my 3 RAM friends. :bucket:
    71tattooguy likes this.
  19. Feb 9, 2025 at 9:07 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Hummmm . . . . the TRD Off Road, at least the 2022, does come stock with upgraded Bilstein 4600 shocks and stiffer coil springs rated 200lbs more than the SR5.
    It really depends on how the OP plans on using the truck. Going Off Road vs just a better ride on the pavement. Certainly 5100s all around would improve the ride. The other stuff coils, AAL and larger tires all depends on does the OP want to just level the truck lift it to go off road or just for looks etc.
    RIX TUX likes this.
  20. Feb 10, 2025 at 1:50 PM
    Rogue_12
    I want a little more clearance and better ride on my daily driver. I don't do aggressive off roading. Just the usual forest/country roads when I go fishing, camping, hiking.
