Question about lifting 3.5 front 2.5 rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808charger, Jan 20, 2022.
  1. Jan 20, 2022 at 11:16 AM
    808charger
    808charger [OP] Well-Known Member
    Joe
    Black 2015 Tacoma TRD
    leveling kit
    So I am going to replace my leveling kit with a lift. I want to do 3.5 in front and 2.5 in back. If I buy 3.5 inch upc, 3.5 inch loaded strut, 2.5 leaf spring and 2.5 rear shock. Anything else I need? Any problems with this? My truck is a prerunner.
  2. Jan 20, 2022 at 11:43 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I think you will need to replace your UCA’s
    wi_taco likes this.
  3. Jan 20, 2022 at 11:44 AM
    808charger
    Joe
    leveling kit
    yes sorry I accidentally said upc I meant to say uca
  4. Jan 20, 2022 at 11:48 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    3" lift is maximum, you do not want to exceed 21" eye to eye with weight on top of shock to bottom of shock.
    Anything more and your boots will self destruct, as is a 3" lift puts considerable additional wear on them.
    Unless you want to go long travel $u$pen$ion.
  5. Jan 20, 2022 at 1:06 PM
    scflyntaco
    scflyntaco Well-Known Member
    brandon
    09 tacoma sport
    lift, supercharger, trd exhaust
    you will probably get some drive line vibrations at the height. look at getting a carrier bearing spacer. you wont have to worry about the needle bearing which is good news
  6. Jan 20, 2022 at 2:09 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    He said hes a pre runner not 4wd no cv boots to worry about.
