Question about lifts
Discussion in 'Suspension' started by Liampiercey9, Oct 15, 2016.
  1. Oct 15, 2016 at 8:50 AM
    Liampiercey9
    Liampiercey9 [OP] New Member
    Liam
    2010 sliver Tacoma TRD
    3 inch lift Flow master exhaust 33 inch Hercules trail diggers
    If I already have a 2.75 inch readylift levelling kit , is there any way I can lift it up to around 4-4.5 or more , I know I could go with a body lift but rather go with something else , just wonder what anyone else did or what I could do
    ChadsPride likes this.
  2. Oct 15, 2016 at 8:52 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    4x4?
  3. Oct 15, 2016 at 9:00 AM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    Money not being a factor, I would ditch the spacer lift and look at OME kits with the dakar rear leafs and maybe an AAL. Maybe a bilstein/eibach combo of Toytec kit for the fronts if you're not into OME products. And I wouldn't touch a body lift other than a Roger Brown/4crawler kit, and I would stay 1". There are lots of ways to get to 3.75" and 4" without spacers and a huge body lift that will make the truck ride better on and off road. If 2wd, maybe spindles,spring and shocks and leafs in the back.
  4. Oct 15, 2016 at 9:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why?
  5. Oct 15, 2016 at 9:02 AM
    ChadsPride
    DB lift of 4x4
    Spindles and coilovers if PreRunner
  6. Oct 15, 2016 at 9:03 AM
    Liampiercey9
    Liam
    Okay thanks for the info, but yes it's 4x4
  7. Oct 15, 2016 at 9:33 AM
    Pigpen
    Dan
    Northwest Montana
    Add a one inch body lift and call it good, if you're happy with the ready lift.
    TacoPretzel89 and ChadsPride like this.
