question about low tire pressure light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WABOOM, Nov 21, 2010.
  1. Nov 21, 2010 at 1:26 PM
    WABOOM
    WABOOM [OP] Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    the low tire pressure light came on yesterday even though all 5 tires are at 28 psi. I had just gotten a carwash, I don't know if that had any thing to do it. Any ideas? The truck has been restarted probably 8 times since then and its still on.
  2. Nov 21, 2010 at 1:27 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    Check the manual, you can reset it with the button under the dash by the steering column
  3. Nov 21, 2010 at 1:33 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    X2...I've had this happen with a cold temperature drop. If everyting looks good just re-set it per the instructions in the manual.
  4. Nov 21, 2010 at 2:13 PM
    Rob H
    Rob H Active Member
    same thing happened to me today..it was cold and raining last night. Tire Pressure light came on. Check the pressure and it looks good. I will be resetting today.
  5. Nov 21, 2010 at 2:17 PM
    myname150
    myname150 Well-Known Member
    Yeah everytime it gets cold my TMPS warning light always comes on. Its quite an annoyance and leaves me worried if i really have a nail or something.
  6. Nov 21, 2010 at 2:47 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I hate that damn light and have learned to ignore it. I've had a couple bad ones ( TP sensors) and of course had to pay someone to replace them. The light is on again, the tire pressure's are right on and I'll just check the tire pressure once in a while and learn to enjoy the light.:)
  7. Nov 21, 2010 at 7:17 PM
    WABOOM
    debadged
    temp here got down to like 17 F last night and was 29 today. I will reset the light . Thanks guys :)
  8. Nov 21, 2010 at 8:21 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Hold the reset button and wait for three flashes of the light. If you have all 5 at the same psi and it still stays on, there's a sensor problem.
    Dealer can read the pressure of each sensor if you really wanted to find out.
  9. Nov 21, 2010 at 11:00 PM
    Bozack
    Bozack Well-Known Member
    Rube
    Dirty South
    2010 DC
    My tps illuminated at around 4900 miles. The tires looked fine; so I didn't bother to check any further. Plus my 5000 mile service was coming up. Anyway, the dealer took care of it.
    However, I did read a tread a few months back that said sometimes the spare tire can cause the tps light to activate. Don't know how true it is, but maybe you can check it also.
  10. Nov 21, 2010 at 11:34 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Check your spare tire. It has a sensor on it, too. Mine was on for a month or so, but finally got around to checking. Sure enough it was low. Filled it up, it's been off since.
  11. Nov 22, 2010 at 2:44 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    He already checked it.
  12. Nov 22, 2010 at 3:52 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Take your pressure in all 5 tires down 5lbs hit re-set, then fill up to where you normally run your tires.
    Example, I run 32lbs. I drop all 5 ( spare inc) to 27 then hit reset, I then fill up to 32lbs. I do this for winter because of the drastic changes.
  13. Nov 22, 2010 at 4:27 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Does anyone know how sensitive the tpms's are? It would be good to know to set them where they would do some good!
  14. Nov 22, 2010 at 4:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I asked the service dept at Toyota that question and I got varying responses between 3 and 5 lbs. From what I've seen with my sensors, that range seems about right. The light comes on when my spare drops that much pressure. I haven't had an issue with the cold yet though so i'm thinking it's closer to 5 lbs.
  15. Nov 22, 2010 at 5:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    The TPMS light will blink constantly if there is a sensor issue.
  16. Nov 22, 2010 at 5:54 AM
    84Hilux
    Gary
    Vancouver, Canada
    Yeah, that sounds about right- a steep drop in temperature seems to drop tire pressure as much as 4 psi- enough to make the light come on.
  17. Nov 22, 2010 at 9:12 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    If you reset it and it still doesnt turn off, welcome to my world. Mine has been on since september, and it doesnt reset when i try. I have to wait till warm weather comes and it turns off on its own. I hate this feature, havent had sensors since 2006.
  18. Nov 22, 2010 at 4:09 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Light only blinks when computer recieves no signal from a programmed sensor. If sensor is not reading the psi that is in the tire, the computer has no way of knowing. If all tires are equal and computer is reset, then it comes back on, you have a problem.
    For the sake of covering all the bases:
    Set all 5 tires psi, push button until light blinks 3 times. If light comes back on, check tire psi again. If all tires are equal, there is a problem with a sensor.
  19. Nov 22, 2010 at 8:25 PM
    WABOOM
    debadged
    I reset the light and I appreciate your help! I think the sharp temp drop is the reason for the light coming on:)
  20. Jul 27, 2011 at 7:35 PM
    bachm
    bachm Member
    Columbus, Ohio
    09 Tacoma
    XTang Hard tonneau cover
    The dealer bent or stripped the valve stem external threads on my sensor unit by not replacing hubcap properly.
    Is it possible to rethread the stem so I can put a new extender on the valve stem?
