Question about mass air flow
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco Sos, May 11, 2013.
  1. May 11, 2013 at 9:20 AM
    Taco Sos
    Taco Sos [OP] Well-Known Member
    Culpeper, VA
    2001 Tacoma DC TRD 4x4
    Bilstein 5100s in front, 265/75/16 BFG A/T, Grey Wire Mod, Deck Palte Mod, Tint, Clarion Head Unit, Infiniti Speakers, Dual 4 channel amp
    I just took my trick to the dealership to diagnose my CEL. They called and said it was my mass air flow meter. Is that the same as a mass air flow sensor?
  2. May 11, 2013 at 11:05 AM
    gobraphil
    gobraphil Well-Known Member
  3. May 12, 2013 at 6:53 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    What's wrong with it?
    Build up or a busted sensor?
    If build up you can get electrical parts cleaner in a spray can to remove the grime.
    DO NOT USE Q-Tips or any tools to clean the sensor.
    It can break.
    If busted you can replace yourself.
  4. May 12, 2013 at 1:06 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    CRC just released a new mass airflow sensor cleaner available at parts stores. It's like $7. I dunno what's in it.
  5. May 12, 2013 at 5:08 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Try cleaning it with spray, then turn the light off. If that doesn't work buy one from Toyota parts barn (or comparable online Toyota part website) and put it in yourself, wicked easy!
  6. May 12, 2013 at 5:34 PM
    Taco Sos
    Culpeper, VA
    Thanks for the replies. Ive cleaned the sensor a few times before with no luck. I was just confused about the dealerships wording. Just an FYI Auto Zone had an identical Toyota/Denso one for $79 and yes it took all of 3 minutes to change. Truck is running awesome now!!! Hoping I start to get better than 14 mpgs now.
  7. May 13, 2013 at 3:39 AM
    TejasYOTA
    Nathan
    Country of TEXAS!
    Bummer that you had to replace it... you can tell if it is busted.
    Look down the tunnel and you will see what will look like a resistor suspended in the air.
    If it is not suspended and you see one of two wires broken, well it's busted.
    if not, it might have been something else within the connector.
    Glad we were able to help.
