Question about Mobtown Bolt on slider install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Superman, Jun 28, 2018.
  1. Apr 5, 2019 at 12:41 PM
    #101
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Where are you guys getting “step 14” from .. I know I’m just a second gen. But when I click then link
    http://mobtownoffroad.com/wp-conten...oma-Rock-Slider-Installation-Instructions.pdf
    Nothing comes up . Found a video on you tube, but the first step is a square washer welded to a bolt .. I didn’t receive that ...
    Do I just use a square washer supplied that doesn’t have a welded bolt ?
    Would be good to find some instructions if anyone knows where they are ..
    @Mobtown Offroad
    Thanks ...
  2. Apr 5, 2019 at 12:51 PM
    #102
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    Inferno__Taco likes this.
  3. Apr 5, 2019 at 12:53 PM
    #103
    Wakecoach
    Kurt
    Sick .. thanks
  4. Apr 5, 2019 at 12:55 PM
    #104
    304_Taco
    Curtis
    Morgantown, WV
    No problem. Not sure when @Mobtown Offroad updated their site.
  5. Apr 29, 2019 at 7:42 PM
    #105
    russ.moura
    russ.moura Well-Known Member
    2019 Cement TRD Off Road DCLB
    Did you figure this out yet? Im in the same boat as far as missing the welded bolt to rectangle piece
  6. Apr 29, 2019 at 7:44 PM
    #106
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Send an email to team@mobtownoffroad.com please if you haven't yet. We'll get you squared away.
  7. Apr 29, 2019 at 7:44 PM
    #107
    Inferno__Taco
    Inferno__Taco Well-Known Member
    Georgia
    2016 DCSB 4x4 TRD Sport
  8. Apr 30, 2019 at 3:24 AM
    #108
    Wakecoach
    Kurt
    Yes . I contacted Mobtown and they sent out the pieces next day
    russ.moura[QUOTED] likes this.
  9. Apr 30, 2019 at 4:15 AM
    #109
    russ.moura
    Thanks for the info! Email sent. To be clear though I didnt buy this directly from Mobtown however the guy I bout it off of said it never came with those pieces. (I watched the video prolly like 50 times and knew what to ask him).
  10. Sep 12, 2020 at 8:43 AM
    #110
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Picked up my rock sliders yesterday and hit a snag early on in the process. For the rectangular washer with the welded on bolt that goes into the hole of the transmission cross member up front, the bolt diameter is too big to fit through any of the 8 holes drilled in the lower part of the slider bracket. Attached is a picture. There are 4 rectangular washers with welded bolts, all the same size. The bolt is about 1/2" in diameter, and the holes are about 3/8" in diameter (I'm sure the actual sizes are metric, but suffice it to say the bolt is larger).
    @Mobtown Offroad can you advise if I'm missing something obvious? Is it possible the wrong size welded on bolts were supplied? The simple solution (in my mind anyway) is to drill out one of the holes in the front bracket large enough for the bolt to fit, but wanted to check first before I start enlarging holes in brand new sliders.
    Edit: I drilled a 1/2" hole in some scrap sheetmetal and the welded bolt just fits through it.
    Edit: I found the written instructions and looking through those and the install video, I'm also missing the 4 beam clamps.
    This picture shows the rectangular washer with welded bolt next to one of the other bolts provided in the ziploc bag, which are smaller and do fit through the holes on the slider front bracket.
    the.sight.picture likes this.
  11. Sep 12, 2020 at 10:31 AM
    #111
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I just looked at mine and I definitely have the smaller bolt welded to a longer piece of metal. I didn’t measure but there is a bolt that might be bigger toward the middle/rear of the slider that I think has a welded metal washer to it. I just did a quick look though and going by feel since I didn’t want to roll around on the ground haha
  12. Sep 14, 2020 at 10:08 AM
    #112
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Update: I spoke with Joe this morning; they recently changed up the hardware and haven't had a chance to update the instructions. Bottom line is the hardware I have is correct and I'm good to go, but wanted to update this for anyone purchasing a recent set of sliders that comes across the same situation I did.
    jowybyo likes this.
  13. Jan 30, 2021 at 11:50 PM
    #113
    mblume7
    mblume7 2017 Cement TRD Pro
    Mitch
    Salt Lake City, UT
    2017 Cement TRD Pro
    Trying to revive an old thread. Just picked up a set of new Mobtown Offroad rock sliders and am in the same situation with the new hardware but don't have the updated instructions. Would you be able to share more details?
    Where do these washers with the welded bolt go? Also the rectangular washer only has a welded nut without the bolt. How does this work instead of the welded bolt on the original version? Any help is much appreciated. Thanks!
  14. Jan 31, 2021 at 8:42 AM
    #114
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    It's been long enough that my memory is a little hazy, but my recollection is the smaller bolt in the second picture is used with the bracket and goes through one of the 8 holes. I think the hole you use is related to long bed vs short bed, and possible AT vs MT. The bigger bolts with the welded nuts are the beam clamps that are installed at the end of video at the back of the sliders (they are a pain to install on the driver side because of the gas tank). Hope that helps.
    [/QUOTE]
    mblume7[QUOTED] likes this.
  15. Jan 31, 2021 at 9:59 AM
    #115
    mblume7
    Mitch
    Salt Lake City, UT
    2017 Cement TRD Pro
    [/QUOTE]
    Thanks so much for the info!
    I do have one more question about this rectangle washer with the weld-on nut. Does this take the place of the rectangle washer with the weld-on bolt that's in the instructions? Do you by chance remember how this is installed? Looks like it goes into the transmission cross member of step 7 and you just screw in one of the smaller bolts. The pictures in the instructions just don't match up perfectly with the hardware included and how it is described.
  16. Jan 31, 2021 at 10:25 AM
    #116
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    [/QUOTE]
    In short, yes.
    Mojo Jojo and mblume7[QUOTED] like this.
  17. Jan 31, 2021 at 8:27 PM
    #117
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Just seeing this question, sorry for the late reply. I see mobtown replied; were you able to figure it out? I remember after getting the front bracket installed it all fell into place.
  18. Feb 1, 2021 at 8:12 AM
    #118
    mblume7
    Mitch
    Salt Lake City, UT
    2017 Cement TRD Pro
    No worries! Yeah I think I’ve got it figured out. Won’t be able to start the install for a couple weeks but just wanted to make sure I could plan accordingly. Thanks for your help!
    Mojo Jojo[QUOTED] likes this.
