question about muffler pipe measurment and inlet/outlet (opinion on flowmaster too)
Discussion in 'Performance and Tuning' started by StreetTaco4Me, May 27, 2013.
  1. May 27, 2013 at 2:00 PM
    StreetTaco4Me
    StreetTaco4Me [OP] Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    I searched, I swear...so thank you for taking time to help...I need some quick advice want to place order today.
    I just picked up a 2013 dbl cab v6 4x2 sb sport...I want to to a muffler swap...stock is too quiet...want a deep throatty rumble...does not have to disturb the neighborhood but would like more sound for sure...do not want serious cabin noise but a little is ok.
    what is the pipe measurement...it gives me options
    am I correct in getting single in/single out 2.5"?
    both of the following have a check mark for v6, looking at either:
    flowmaster 40 delta flow
    flowmaster 50 delta flow
    Is a muffler shop the best place to have it welded for install (not sure if my city has one) or can I take it to any mechanic shop?
  2. May 27, 2013 at 4:00 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    05 prerunner trd off road DC
    Red hot glass pack muffler dumped preaxle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front and modified zuk mod coil spring lift for about 2" in rear paired with 5100 also. C channel front bumper. Maxxis bighorn 255/85/16
    Flowmaster let their patent a couple years ago and flowtech makes the same thing at half price or so. 2.5 is the diameter but I think a lot of ppl go 2.25 and have muffler shop flare them out or tail pipe (if that's possible) in for a tighter fit so there is a little less welding.
  3. May 27, 2013 at 4:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Slowmaster LOL
  4. May 27, 2013 at 4:28 PM
    White Horse
    White Horse "If you didn't know,now you know"
    Rick
    Seminole,Fl
    2011 Lifted Super White TRD Sport
    Maxtracs spindle lift at 6.5"lift Bilstien 5100's set at 1.75 and 3/8" top hat spacer with rear 4"blocks and 1.5"aal's for 5.5"lift.
    Yeah, 2.5 would be right,i run flowmaster 40 - single in double out. I have video's of mine on youtube at blackhorse11773 that way you can hear for yourself. I had mechanic shop intall for me-parts/labor $250 out the door.
  5. May 27, 2013 at 8:41 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    also was looking at magnaflow...but confused as I have no idea what each of their mufflers is designed for...is there a magnaflow that is deep and throaty not ricey...do not want any rice sound at all...want all throat
    OK I just measured the tacoma stock muffler:
    21.5 inches...front of the muffler has a pipe entering on the high part...back of the muffler has a pipe exiting low...
    do I need an offset?
    also noticing that nothing fits the same as the 21.5 total inches shoul I get one a little longer or shorter or does it matter?
    man I am confused and could use some help
  6. Jun 6, 2013 at 4:13 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    I ended up going with flowmaster 50 delta flow...got the 2.25 single in/out offset/offset...I hope I did that right because the front of the muffler has a pipe entering on the high part...back of the muffler has a pipe exiting low...I am going to get it installed tomorrow for $60...$100 for the muffler shipped...so I might get out of this for only $160 installed...that would be nice
  7. Jun 7, 2013 at 12:23 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Just got the Flowmaster 50 delta flow installed...sounds exactly like what I wanted...surprisingly loud at first but that is just because the stock is so quite...good flow no power loss...settled down a rough idle that I had from the factory...sounded great did not hear any drone...per se it is a little louder at around 2k rpm but that makes sense it is when the engine is working...also if you wanted it quite you would not have changed mufflers right?
    I order 2.25" offset/offset...I should have order center in/offset out to make it easier to install...the shop had to cut some of the stock piping in front of the muffler to get it to fit properly...but they did it without issue.
    I called around to a few shops these guys quoted me $55 replaced and welded and I paid $55 installed and welded...good deal
