Question about old oil jugs?
Discussion in 'Off-Topic Discussion' started by winkel, Oct 28, 2017.
  1. Oct 28, 2017 at 1:45 PM
    winkel
    winkel [OP] Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Not sure where to post this so I'll drop it here and see if any of you have any ideas on this.
    I'm not a tree-hugger, but since I do all of my own oil changes, I'm getting a lot of 5 quart oil jugs stored up in my garage. I give my used oil to a friend with an oil burning furnace in his shop, but you never get five quarts back out of the engine during a change.
    If I could buy oil locally by taking in my own jug, I'd do it. Short of throwing my old jugs in the trash, what other options are there. I don't know of a recycling place in the area that would take them. I hate for all of them to end up in the landfill.
    Any thoughts??
    DustStorm4x4 likes this.
  2. Oct 28, 2017 at 1:51 PM
    tcjacado
    tcjacado Well-Known Member
    If you have a local chain like pep boys or auto zone.... I believe They are oil collection sites. Other wise i would ask your local auto parts store or use Google and enter oil disposal or oil collection with your zip code
  3. Oct 28, 2017 at 2:43 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I think he means the jugs.
    OP-i always put mine in the recycle bin when they were empty. If you want you can let them drain out upside down overnight to get most of the oil off the sides. But the jugs have the recycle thing on them, at least mobil 1 did. So after dumping into my engine, into the recycle bin they went.
    Watt maker likes this.
  4. Oct 28, 2017 at 8:35 PM
    winkel
    Corydon, IN
    Yes, the jugs. I end up with more empties than full ones with used oil in them. We don't have a recycle place around here that I'm aware of that takes plastic. I'll give some of the auto parts stores in the area a call and ask about it.
    DustStorm4x4 and tcjacado like this.
  5. Oct 28, 2017 at 8:39 PM
    tcjacado
    Where are you located... I c Nashville Illinois. I typed that in and got this place
    http://www.browncountyrecycles.org/drive-thru-recycling-at-the-central-recycling-center
    And this
    http://local.bcdemocrat.com/nashvil...nt/brown-county-recycling-center-812-988-0140
  6. Oct 28, 2017 at 8:46 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Throw them in the garbage !!!
  7. Oct 28, 2017 at 8:48 PM
    david-oregon2999
    david-oregon2999 Well-Known Member
    I'd like to see a closed product loop. If you sell a car, you must take that car back at the end of its life. If you sell a jug of oil, you must take the jug and used oil back at the end of their lives.
  8. Oct 28, 2017 at 8:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Recycle
  9. Oct 29, 2017 at 1:16 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    all cars will be electric in twenty years. Heard on the radio that great strides are being made with batteries.
  10. Oct 29, 2017 at 4:33 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I honestly think a lot of recyclables are still hauled to the dump even after being put in the correct bin. The market for recycled plastic is just not there
  11. Oct 29, 2017 at 5:13 PM
    OZ-T
    Peter North
    British Columbia
    All new cars maybe
  12. Nov 1, 2017 at 2:13 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This is true, at least in my area. Not because of low demand for materials, but because of impurities. The material needs to be pretty clean or it will not be recycled. E.g. plastic or foil food containers with food on them do not get recycled. So the used oil jugs might not be recycled if they are contaminated with used oil, sludge or sediment.
    OP I suggest you find some cheap solvent (mineral spirits, carb cleaner, etc) and put a couple ounces in each jug then shake it around real good to clean the sediment and sludge from the jugs, then dump that waste in with your next oil recycling. Repeat if necessary, should get the jugs pretty clean. Then put 'em in the recycle bin. That's what I would do. Actually I am facing sort of the same container backlog... not with my fresh oil jugs because those get drained real good and go straight to the recycle bin. But I use 6.5-quart laundry soap containers for recycling used oil, they are big and made of real heavy plastic with a tight cap. Anyway they get nasty after 8 years of use (thick layer of sediment and sludge at the bottom) and need to clean them out before recycling. Been saving up the new jugs, have about 4 of them getting in the way because my garage is full of toys and stuff. Quality problems LOL!
  13. Nov 1, 2017 at 2:15 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I just take the jugs to autozone, dump the oil in their container, then throw the jug in the bin right next to the oil recycling station. Then who knows where they go...
