Question about OME 886 springs
Discussion in 'Suspension' started by cfagan14, May 12, 2012.
  1. May 12, 2012 at 3:05 PM
    cfagan14
    cfagan14 [OP] GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    So I'm planning on getting an ARB winch bumper for my Tacoma but I want to maintain the stock height, so would the 886 springs suffice or will they be higher than stock?
  2. May 12, 2012 at 3:06 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Higher than stock and ride very rough until the bumper is put on.
  3. May 12, 2012 at 3:07 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Madison, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Higher than stock by about 2-2.5 inches.
  4. May 12, 2012 at 3:09 PM
    cfagan14
    Atlanta
    Dang you guys are fast. Okay well then what kind of springs should I get to compensate for the 200lbs+ of weight on the front end?
  5. May 12, 2012 at 3:15 PM
    RadRed06
    Daniel
    Madison, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Eibach/Toytec (1.6 inches of lift) coils may be your best bet for retaining stock height as they will sag some. You may still get somewhere in the .5-1 inch range of lift though.
  6. May 12, 2012 at 7:52 PM
    cfagan14
    Atlanta
    Okay I appreciate the guidance a lot. My last question now is, can I use the Toytec springs on my stock Tacoma shocks? I have a base 4x4 so I don't have the TRD shocks.
  7. May 12, 2012 at 8:47 PM
    RadRed06
    Daniel
    Madison, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Yes you can run the Eibach coils on stock shocks, though the ride will not be as good. Pairing the eibach coils with 5100s set at 0 would greatly improve ride quality, but yes stock shocks can be used although most would not recommend it.
  8. May 13, 2012 at 8:34 AM
    Large
    Large Red
    ^ Get the eibachs & 5100s, you'll be happier in the long run if you fork over a little more dough.
