Question about Pioneer AVH-X5500BHS
Discussion in 'Audio & Video' started by NorCalTRD, Mar 29, 2013.
  1. Mar 29, 2013 at 3:35 PM
    NorCalTRD
    NorCalTRD [OP] Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    Starting to upgrade my sound and Im pretty set on the X5500.
    I was wondering though if I can use Google Maps on it through my android phone?
    Also, what would be good speakers to pair with this headunit?
    Im not interested in being super loud, just reasonably loud and good quality for my own enjoyment.
    Would you recommend an amp and sub or just stick to the HU and upgraded speakers?
  2. Mar 29, 2013 at 4:42 PM
    NorCalTRD
    Northern California
    Here's what Im considering:
    http://www.crutchfield.com/S-CUubWBRm9bA/p_130X5500BH/Pioneer-AVH-X5500BHS.html
    Polk DXi 6500 Components for front
    http://www.crutchfield.com/p_107DXI...?showAll=N&search=Polk_Audio_DXi6500&skipvs=T
    Polk DXi 650 for rear
    http://www.crutchfield.com/p_107DXI650/Polk-Audio-DXi650.html
    Sound Ordinance 75w x 4 Amp
    http://www.crutchfield.com/p_777M4075/Sound-Ordnance-M-4075.html
    Infinity 10" 200W Powered Sub
    http://www.crutchfield.com/p_108BASSLIN/Infinity-BassLink.html
    I know I will need adapter mounts for the front and rear speakers, and that I need to install an 8 gauge fused power cable to the sub and amp and then ground the sub and amp somewhere.
    Also a faceplate for the HU. Anything else I should need?
  3. Mar 31, 2013 at 11:30 PM
    NorCalTRD
    Northern California
    Can anyone chime in with some feedback?
  4. Apr 1, 2013 at 3:39 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    8AWG for power to the amplifier and subwoofer is too small. I'm thinking 6AWG minimum to a distribution block, then 8AWG to each component out of the block.
    Those Polk speakers look to me like the ones that are awesome on paper and in practice disappointing. I have nothing to base this on except intuition.
    I have no experience with Sound Ordinance either, but I wouldn't buy that amp with your money. I think you're better off with an affordable Alpine.
    In my experience powered subs don't live up to expectation. Definitely go listen to that thing somewhere before you buy it. Consider a 5 channel amplifier and a component sub instead of a 4 channel amplifier and powered sub.
  5. Apr 1, 2013 at 4:23 PM
    aaronc7
    aaronc7 Well-Known Member
    Aaron
    Navarre, FL
    2013 DCSB 4x4 TRD Sport
    I think you need the 8500 model to get the "appradio" functions for android. If you really look into it, you'll see that on the lower end models, a lot of those cool features only apply to Iphone. I have the 2500, which is the same as the 5500 I believe as far as apps/compatibility, and I can't do anything thru the USB. I can connect via BT for phone stuff, audio over BT and pandora.
    Even thru appradio, you are just using built in apps on the headunit, using the phone for gps and/or data connection. If you root your android, there appears to be something cool called ARLiberator, where you can basically turn your HU into a remote screen for your phone:
    https://play.google.com/store/apps/details?id=com.kyle.arliberator&hl=en
    I looked into it when researching headunits, but ultimately said screw it and just got a basic double din unit. Me personally, I rarely use/need navi on the go on a daily basis, and I have a good garmin with lifetime map updates to use for big trips, etc. I feel the phone/car integration piece is coming along, but not quite 'there' yet to be extremely useful.
