Question about Pro Comp 8089
Discussion in 'Wheels & Tires' started by CBR1000RR, May 1, 2013.
  1. May 1, 2013 at 11:04 AM
    CBR1000RR
    CBR1000RR [OP] Well-Known Member
    Maryland
    03 TRD DoubleCab
    Toytec ultimate lift kit
    I have an 03 double can and want to put these wheels on my truck. 4wheelparts has them in 16x8 4.5" BS and a 0mm offset. I want to know if this wheel will clear the brake caliper on my truck. I've tried searching but most of the threads are for 2nd gens...
  2. May 1, 2013 at 11:09 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  3. May 1, 2013 at 11:24 AM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
    Okay thanks. Do you have these wheels?
  4. May 1, 2013 at 1:36 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    zero off set ?
    thought Jeeps had zero off set !?
    purdy sure 1st gen Tacoma require some off set to clear the calipers.
    This off set measurement could vary some,
    dependent on the actual cone shape/depth of the wheels center chunk
    and the form of that.
    Some wheel center chunk designs are more forgiving then others.
    my current wheels have -11 mm off set @ 4" BS
    These have a specifically designed center chunk specification,
    regarding the construction of the center chunk's design.
    Designed specifically with the 1st gen Tacoma in mind.
    With other wheel designs -11 mm may not clear the caliper.
    So be sure to test fit the wheel before installing the tire.
    That way they can be returned/exchanged unused. ;)
    If you stick with the factory 4.5" BS'ing
    you could be limited tire size to no wider then 10.50"
    * 4.0" BS'g allows for 10.50" width tires, as well 11.50" widths (285's/33's)
    @ 4.5" BS - 11.50" width tires will nicely polish the frame at full steer. L/R lock.
    As well, maybe rub the UCA slightly, especially if aired down.
    understanding wheel off set/back spacing
  5. May 1, 2013 at 1:39 PM
    Monster Coma
    Corey
  6. May 1, 2013 at 1:40 PM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
    I just want to get the right wheel the first time because I am going from stock to 3" lift wheels and 33's all at once so I'm just trying to get all my ducks in a row so I don't have any set backs and I don't have to drive my truck around with a 3" lift and stock wheels and tires.
  7. May 1, 2013 at 1:43 PM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
  8. May 1, 2013 at 1:44 PM
    Monster Coma
    Corey
    look at your title bud
    edit: my bad I thought I read 8069, do you mean 8089 or 7089?
  9. May 1, 2013 at 1:46 PM
    CBR1000RR
    Maryland
    03 TRD DoubleCab
    Yeah that's my fault but the 8089 and 7089 are the same wheel except one is all black and the other is black and polished....that 8069 is a completely different wheel then the ones I am asking about.
