Question about rear diff lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by EbonMoss, Feb 2, 2024.
  1. Feb 2, 2024 at 9:51 AM
    EbonMoss
    EbonMoss [OP] New Member
    Ebon
    2003 Tacoma Prerunner v6 2WD
    Hello, I'm relatively new to trucks but trying to learn. Was given an old beater of a truck and am currently researching a 2wd to 4wd conversion. I know everyone's probably going to say just go buy a 4wd truck but honestly I just wanna take the project on anyways. Now my question is this; my tacoma has a rear differential lock and in my research I can either choose an automatic differential disconnect or manual locking hubs. So since the tacoma has the rear diff lock does that mean it already has the vacuum actuator on the transfer case? If so, would ADD be the way to go?
    Area51Runner likes this.
  2. Feb 2, 2024 at 9:55 AM
    02hilux
    Planet: EARTH
    For your 03? From factory, it'll have an electronic actuator but if you're converting, go manual locking hubs and find yourself a 23s tcase
  3. Feb 2, 2024 at 10:17 AM
    EbonMoss
    Ebon
    Thanks, manual hubs seemed like the better option just wasn't sure and sorry still new on the lingo but what do you mean by 23s? Is that a model number of of the transfer case?
  4. Feb 2, 2024 at 10:27 AM
    02hilux
    Planet: EARTH
    V6 use 23 spline tcase. 4cyl use 26 spline. Won't interchange unless you change the input shaft
  5. Feb 2, 2024 at 11:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sir, your rear differential lock has absolutely nothing to do with your front end.
    Just clearing this up so you don't get confused by additional responses later.
    Your rear differential locker, basically "locks" the rear end so both wheels receive power.
    When your locker is not engaged, in an off-camber situation, the wheel with no resistance (or minimal resistance) will spin while the wheel with traction sits idle. This is an open differential that allows this to happen.
    By engaging the rear locker, now the "free spinning" wheel turns along with the wheel with traction. This one wheel will enable you to gain the traction you otherwise wouldn't have.
    Automatic disconnecting differential, and manual hub setups, are specific to your front end in a 4x4 vehicle and have absolutely no bearing on the rear locker.
    TACOTU3 and 02hilux like this.
  6. Feb 2, 2024 at 12:11 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Manual hubs will be easier because you won't have to worry about wiring up an A.D.D. (automatic disconnecting differential).
    You'll also want a J-shift transfer case (with the 23 splines) like @02hilux mentioned above.
    Other parts you'll want to start sourcing:
    - 4wd steering knuckles
    - Manual Hub CV axles
    - Manual Hub Front Diff (w/ 2 mounting bracket arms)
    - Front Driveshaft
    - New (shorter) rear driveshaft
    - 4wd Transmission (A340F or R150F)
    I'm sure there's more, but those are the main items
    Kwikvette likes this.
  7. Feb 2, 2024 at 12:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Should go manual transmission, the drive-by-wire setup on the 03-04 autos means finding a 4x4 transmission specific to one of those two years
    Spindles can be reused pressing everything out (and ensuring you have new bearings which is a plus)
    But yeah, your list covers it
    Red_03Taco[QUOTED] likes this.
  8. Feb 2, 2024 at 3:22 PM
    02hilux
    Planet: EARTH
    Just bypass the 4wd conversion and go straight solid axle... that's my .02
  9. Feb 2, 2024 at 3:31 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    Couldn’t he also use an 01-02 4Runner transmission? I agree though might as well manual swap it at the same time, huge improvement over the auto.
