Question about rear wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InfamousTonyTaco7714, Aug 29, 2013.
  1. Aug 29, 2013 at 11:07 AM
    InfamousTonyTaco7714 [OP] Well-Known Member
    Lucas
    Wilkes, NC
    09 SR5 DCSB 4x4 Timberland Mica
    Borla Catback, 6 inch Pro Comp Stage 1 17x9 Matte Black XD Revolvers, 285/70/17 Radar Renegade R7, Pioneer Double Din, Iron Cross Side Steps, Tactical Armor Group Front Bumper, ARE MX series camper shell, Geared 4.10
    I have a very random question. On thursday nights i always run up to the local dragstrip. Every once in awhile, a mid size truck will come thru and ill run my truck down the dragstrip beside em (legal of course). And as lots of people know, before people run, theyll burn their back tires so theyll catch traction when they take off. Well, only my passenger rear tire spins, not both. I was wondering what causes this and what i can do to make them both spin. Thanks.
  2. Aug 29, 2013 at 11:12 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Are you turning off the traction control and the "auto LSD". Wait! Does your year have those? I am not sure?
  3. Aug 29, 2013 at 11:13 AM
    Lucas
    Wilkes, NC
    I turn off traction control but the auto LSD stays lit on the dash until i hit 35 mph.
  4. Aug 29, 2013 at 11:13 AM
    Nfurtado77
    Nfurtado77 Well-Known Member
    Turn off traction control and all aids I'm guessing the trac senses the wheel is slipping so it puts all power to that wheel.
  5. Aug 29, 2013 at 11:14 AM
    Nfurtado77
    I was a little late ahah beat me to it.
  6. Aug 29, 2013 at 11:16 AM
    Lucas
    Wilkes, NC
    Is there any way to make it to where both wheels will spin and keep spinning until i stop?
  7. Aug 29, 2013 at 11:16 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Basically you have a open rear differential. The computer will apply the brake to the spinning wheel in order to send power to the wheel with traction. It's not a true limited slip. Toyota calls it auto lsd. If you turn off your traction control. You are disabling it an will spin one wheel.
  8. Aug 29, 2013 at 11:20 AM
    TacoSupreem
    Hayden
    Kentucky
    The best way around this is to launch in 4wd hi
  9. Aug 29, 2013 at 11:23 AM
    jw1983
    Alberta
    ^^^DO NOT DO THIS! Don't do anything on pavement with 4x4 engaged.
  10. Aug 29, 2013 at 11:25 AM
    Lucas
    Wilkes, NC
    Trust me, i know much better than to do it in 4x4 hi...Im much much smarter than that haha
  11. Aug 29, 2013 at 11:25 AM
    Lucas
    Wilkes, NC
    And im asking how to make both back wheels spin at once...4x4 is definitely not going to make them do that.
  12. Aug 29, 2013 at 11:26 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    It does that because you have an open Deferential or if you have positive traction it is worn out.
    As to what to do the best thing is you can change the diff to a positive traction. There are several other things that can be done, but I do not recommend them if you want to keep this a daily driver. I would add that changing to a positive traction will cause faster tire wear even without using the truck at the drag strip.
  13. Aug 29, 2013 at 11:27 AM
    Lucas
    Wilkes, NC
    How do i change to a positive traction?
  14. Aug 29, 2013 at 11:37 AM
    jw1983
    Alberta
    Oh you know there has been threads about people asking about it. Just making sure that you know not to, which is good that you do.
  15. Aug 29, 2013 at 11:37 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Best way is to install an ARB locker, but this is about $900 plus labor.
  16. Aug 29, 2013 at 11:37 AM
    savedone
    Gerald
    Texas
    If you are not familiar with doing this I suggest using a mechanic. Or I suggest that you Google some videos on replacing differentials or installing positive traction if you really want to tackle it yourself. There is a lot to learn about this.
  17. Aug 29, 2013 at 11:39 AM
    savedone
    Gerald
    Texas
    They are not really for drag racing.
  18. Aug 29, 2013 at 11:39 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Spool.
  19. Aug 29, 2013 at 11:40 AM
    TacoSupreem
    Hayden
    Kentucky
    The only other way is to install a true limited slip like a auburn lsd or a locker. Both are very expensive options. I would just launch in 4wd hi on the occasions that you run it down the strip.
  20. Aug 29, 2013 at 11:41 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    If you launch in 4 wheel drive your truck will instantly explode too much traction:D
